03-11-2019, 05:58 PM | #1 |
Rep 119
IAC valve same as fuel tank breaker valve?
Hey there - quick q - is the fuel tank breather valve same as the idle air control valve on these cars?
If not where’s the idle control valve located? I found the fuel tank breather valve as the one in the valley |
03-11-2019, 06:05 PM | #2 | |
Rep 119
ICV is p/n 13417838024 FBV is p/n 13907838281 Which one may be responsible for hesitation during acceleration? If either.. |
03-11-2019, 11:52 PM | #3 |
Rep 1,046
IAC, which means idle air control valve, (different manufacturers call it different things) is a valve that controls your idle speed, allowing the correct amount of air past the throttle plates to keep the engine running at the desired idle speed.
A fuel tank breather valve controls the pressure in the fuel tank. |
03-12-2019, 08:12 PM | #4 |
Rep 1,286
AS above they have different functions. Both are on top of your engine under the plenum (I've replaced both). Fuel tank breather is cheap and pretty easy to get at, but idle control valve is expensive and a bit deeper in the "V"
If your car dies after getting gas at the gas station while sitting at a red light, and idle speed hunts up and down, get a new fuel tank breather valve. If you car, upon cold start, has a hunting idle and dies when cold, then consider replacing the idle control valve. |
marcster19.50 |
04-01-2019, 05:32 AM | #5 | |
Rep 84
Running into this issue myself... although none of the above scenarios has occurred to me. After some spirited driving I came to a red light and boom. Idles drop below 500 then bounce back above normal then back down, back and forth. I'm thinking ICV... |
04-01-2019, 07:35 AM | #6 | ||
Rep 1,389
1BlackDropTop18.50 |
04-05-2019, 04:08 PM | #7 | |
Since 2010
12
Rep 39
idle hiccup
It's a 2011 w/138k miles, manual trans. I'm at the end of a 2018 refresh with this car, owned it since new and this pops up in the last 2 months. within the last 6 mos I've replaced; actuators, ignition coils & plugs, rod bearings ... she's running like new except this one problem/ hiccup. any ideas?
///M3 2011 e93 6MT JB/FR APEX HID20k Atak Eibach Springs Wrapped Trim PremPkg TechPkg NAV HFS +Sound
04-05-2019, 09:37 PM | #8 |
Rep 119
Which one If either causes surging and hesitation at cold start and run in first and even sometimes second gear? Not as much the idle speed but the car itself - surges, pulls back and surges again ? Or is it just bad gas ?
wfdeacon881105.00 |
04-05-2019, 10:44 PM | #9 |
Rep 4,107
Having had the FBV issue, what you describe is not the FBV... FBV causes idle to drop while idling at a stop light. It will bounce back up above normal levels briefly but not surging. And I never had the issue at cold start up, usually after filling the tank.
2021 X3 M40i
wfdeacon881105.00 |
01-03-2021, 06:28 PM | #10 | |
Rep 69
01-04-2021, 06:22 AM | #11 | ||
Rep 724
01-04-2021, 07:54 AM | #12 |
Merlin
474
Rep 730
Drives: 2012 BMW M3 6MT w/ZCP
I think that special emissions warranty will or should cover the cost of replacement of either of those items.
I can look up the actual link if people want, but there's some posts here on Bimmerpost that should be searchable and reference how the special fuel and emissions warranty works. It's possible I may be incorrect- but double check to see if either of those items are covered. Cheers, Merlin
2012 E92 M3 ZCP | 2008 E90 335xi | 2008 E90 335i | |
01-08-2021, 11:09 PM | #13 |
Rep 17
01-09-2021, 12:19 AM | #14 | |
Rep 860
01-09-2021, 07:56 AM | #15 | ||
Merlin
474
Rep 730
