03-06-2019, 10:52 AM | #1 |
Rep 448
No oil level reading
Can someone help me understand how to get a bloody oil reading out of this car, changed the oil, ran it for a while, let it sit and then tried to get a reading - nothing. Next day try again - nothing. Wtf!
03-06-2019, 10:58 AM | #2 |
Rep 1,930
Hold on to the BC stalk to reset your oil levels. A few tries should get your oil level readings.
LuckiSevens227.00 |
03-06-2019, 11:04 AM | #3 |
Rep 448
03-06-2019, 11:07 AM | #4 |
Rep 139
Yeah it takes time sometimes to read. Has a clock symbol until read
LuckiSevens227.00 |
03-06-2019, 11:15 AM | #5 |
Rep 979
As long as you put in 8.5 quarts you should not worry. It will eventually show a reading.
LuckiSevens227.00 |
03-06-2019, 03:29 PM | #6 |
Rep 855
Lets go back to the basics here. Are you letting the car completely get to operating temp? If you're in nyc/nj (its been cold here!), it will take at least ten+ miles before its hot enough for a read.
Manually initiating an oil read through the BC button will not work, unless you're warmed up Ditto Mvy
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
wfdeacon881105.00 |
03-06-2019, 03:38 PM | #7 |
Rep 2,747
It will only measure when cars at temperature too.. I always measure how much comes out of it when I change mine. That way you know how much to put in without concern..
9ers
03-06-2019, 04:51 PM | #9 |
Rep 1,881
its must be because oil level readings are a scam by backstreet mechanics to scare people into changing their oil.
03-06-2019, 07:07 PM | #10 |
Rep 448
03-06-2019, 07:08 PM | #11 |
Rep 448
03-07-2019, 11:56 AM | #12 |
Rep 448
03-07-2019, 01:12 PM | #13 | |
Rep 1,389
Self proclaimed engine building expert with enough knowledge to be able to claim the S65 does not have any rod bearing issues. Check. Complete moron. Check. |
03-07-2019, 02:06 PM | #14 |
Rep 803
After oil change, in my experience, it takes much, much longer than just coming to normal temp to get a first reading. I've given up on getting one right after and just drive the first day, check on second trip or next day.
As long as I know what I put in I'm not worried about it for 10-30 miles.
Objects in mirror are slower than they appear.
03-07-2019, 02:10 PM | #15 | |
Rep 2,138
Drives: 2011 E92 M3
S65 oil capacity is 8.8L or 9.3Qt. If you let it drain fully and get the oil out of the filter housing properly, then put in 8.8L and forget about it. Cheers,
03-07-2019, 06:03 PM | #16 | ||
Rep 448
03-08-2019, 01:50 AM | #18 |
Rep 2,336
It will take longer for you to get a reading sitting there idling as oil takes forever to get to temp @ idle speeds.
LuckiSevens227.00 |
03-08-2019, 08:11 PM | #19 |
mTekMods
2142
Rep 2,901
205*F for oil level reading iirc.
LuckiSevens227.00 |
03-09-2019, 08:22 AM | #21 |
Rep 498
Drives: 2010 E92 M3
Car won't give you a proper reading until it hears you admit it needs rod bearings
2010 E92 M3 // IG: @commuter_blue
LuckiSevens227.00 wfdeacon881105.00 |
03-09-2019, 08:49 AM | #22 |
Rep 448
