      11-29-2018, 08:54 PM   #1
Freiheit
Drives: 2011 Competition Coupe
What shocks/struts should I get to go with the Dinan coils?
My car is a ZCP with the Dinan Stage 1 coils. The ride is comfortable on the highway but its a little rough on the street. No over bounce but I definitely notice the bumps. I believe that the lowered ride height has the dampers a bit below their sweet spot @ static height. I'd like to keep EDC. What shocks and struts can I use with these coils to get better ride quality?
      11-29-2018, 10:28 PM   #2
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
I believe they were designed to complement the oem shocks. The Dinan coils are such a minor drop i doubt you'll notice a difference replacing with an aftermarket shock
How many miles do you have?
      11-30-2018, 10:16 AM   #3
Richbot
Drives: Jerez Black E90
I think you're boned unless you go to the Bilstein damptronic or similar, and then you might as well sell the Dinan setup and get something which you can tailor your rates how you like it and comes with good damping as part of the pacakge
      11-30-2018, 08:12 PM   #4
Freiheit
19k
      11-30-2018, 08:17 PM   #5
Freiheit
I tried searching Bilstein "damptronic" and all I could find was coilovers. Don't they make "damptronic" shocks and struts without going to coilovers?
      11-30-2018, 08:34 PM   #6
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
19k
Keep OEM or go coilovers and ditch the dinan springs
      12-01-2018, 07:06 AM   #7
Montaver
Montaver's Avatar
Drives: G87 M2 & M340i LCI
Is it just the springs or full stage 1 kit? It should come with smaller bump stops and modified top mounts to retain the suspension travel. I guess you could get Moton, MCS , JRZ etc. custom valved for softer springs which would give you a more sophisticated damper setup but it loses EDC. For the street I don't think there is much better than OEM, you could also try going back to ZCP springs.
      12-01-2018, 06:11 PM   #8
Freiheit
I have no idea if the SRQ kit is on the car or not.
I've asked elsewhere if its possible to see anything on a completed install to determine if the SRQ parts are there and apparently I'd have to dismantle a corner and inspect the parts to find out.
      12-02-2018, 02:30 PM   #9
Montaver
Montaver's Avatar
Jack the front side up, you should be able to see the bump stop pretty easily which will give you a good idea if it has it or not. Infact I can see my bump stops without jacking up the car but its stock height.
      12-02-2018, 04:20 PM   #10
Freiheit
I'll give that a shot next weekend. Thanks for the info.
      12-04-2018, 10:19 PM   #11
M3ANMACHINE
Admiral
M3ANMACHINE's Avatar
Drives: 2011 E90 M3 + 2014 F15 X5
You'll be fine with stock struts honestly.
2020 FORD RAPTOR
2014 F15 X5 | M-SPORT
SOLD
2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3
shimmy232350.00
