09-06-2011, 07:48 PM | #1 |
Rep 869
Help! Soft brake pedal after pad change.
Changed all 4 pads out (to Pagid-19s) yesterday for track event next weekend and now have soft brake pedal--actually, feels like mostly more travel to floor, not necessarily spongy, but feels terrible! I did NOT bleed this time, having done a full flush last month for track day. Brake fluid reservoir is topped off at max level with Motul 600.
It's the bleed isn't it? I should just do it, right? But there's no way I could have intrduced air into the system by just changing the pads. It's definitely different than before though. I also haven't bedded them in yet. Anything else it could be? Thanks.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
09-06-2011, 08:13 PM | #2 |
Rep 1,285
Drives: A Car
I would start with a bleed, its most likely the problem. At the very least its probably the best place to start when looking at brake issues. Bedding shouldn't affect pedal travel - it will change the bite and release.
09-06-2011, 08:29 PM | #3 |
Rep 7,887
Do a proper bed in on the pads.I usually find that after a pad change that my pedal is not as good as when they have been bedded in properly.Failing that a good bleeding might be the fix.I usually do a bleed every 4-6 weeks during the track season.
09-06-2011, 08:34 PM | #4 |
Rep 869
Thanks, those were the two things on top of my list, bleed and bed. We'll see...
09-12-2011, 12:34 PM | #5 |
Rep 570
Sleeper519: How'd you make out w/the soft pedal? I just changed my brake pads this weekend to Cool Carbon pads and installed ATE Blue fluid. Pad install went smoothly, no rattles or squeaks, and the bedding process went well, also (great pad transfer onto the rotors w/good uniformity). However, after two very careful sequences of bleeding w/a Motive pressure bleeder, which has always produced great results...at least on my Porsche Cayman, I have a slightly soft pedal. It firms-up w/a few quick taps, so it appears to be air. Looking into it now, but was wondering your end results.
-Brian |
09-12-2011, 03:48 PM | #6 | |
Rep 1,286
09-12-2011, 06:36 PM | #7 | |
Rep 8,076
Drives: 11 E90 M3 Individual
Seriously, in regards to the brakes, bed first and then bleed.
2018 F30 320iX Melbourne Red
09-12-2011, 08:25 PM | #8 | |
Rep 869
I bedded the pads (3X) with some improvement. Then pressure bled them with Motive with also slight improvement. I've since been told that the old fashioned way of "friend-with-foot-on-the-pedal" bleeding provides better pressure for getting small air bubbles out. Anyhoo, I ran great at the track event, had a blast, and proceeded to melt (seriously) my stock rotors from the heat. So I'm using my Search button to research BBKs... I see one in my near future, but damn $$$$! This will certainly be my next thread. To be continued...
09-13-2011, 12:24 PM | #9 |
Rep 1,286
Yes, was at Road Atlanta, nice weather and great time.
I think you and I have the same experience with the pads, it's not abnormal, it just feels different. I bet when you remove these pads and put your stock pads back, the pedal will again be as firm as you remember it. I really doubt you have any "micro-bubbles" or any air in your system for that matter. |
09-13-2011, 12:33 PM | #10 |
Rep 5,506
I would definitely recommend the old fashioned way of brake bleeding with someone pressing the pedal over the pressure bleeder.
When you replaced the pads, did you crack open the bleeder to let the brake fluid out? |
09-13-2011, 02:15 PM | #11 |
Rep 869
Z K, No, when I change pads I just muscle the piston back open, but never open the fluid system unless I'm going to bleed or flush (with the system pressurized).
Victor, Yes, great time at RA. Never saw so many E92 M3s at one event before! I saw your SC tag and meant to come over and meet you. Maybe next time.
09-13-2011, 03:56 PM | #12 |
Rep 1,286
Yes, there sure were a lot of late model M3s. I was parked over by the registration shed next to Brian in a blue E90 M3, then a white '11 GT3 (driven by Steve a Road Atlanta regular) and a silver E92 M3 (that wasn't you was it?).
How did you fry your brakes (I've done it with stock pads but never Pagids and I've gotten those stinkin' hot before)? I never got mine all that hot that weekend and my instructor was encouraging me to "brake a little sooner and softer" for which I was not a good student and ignored. |
09-13-2011, 04:30 PM | #13 | ||
Rep 5,506
Google and you'll find a lot of articles regarding ABS system damage from pushing the piston in without opening the bleeder. Here's one: http://autorepair.about.com/library/a/1i/bl836i.htm Another: http://www.brakeandfrontend.com/Arti...irst_time.aspx Quote:
09-13-2011, 05:26 PM | #14 | |
Rep 869
I'm not sure how that would lead to a soft pedal though, unless you are doing some permanent physical damage to the master cylinder. Most everybody I've talked to on this subject either uses a piston retraction tool , a large C-clamp, or slow manual traction (muscle). No one has mentioned opening the bleed valve. There seems potential to suck back air into the lines unless you've pressurized the system.
09-13-2011, 05:33 PM | #15 |
Rep 869
I was on the back row of the main paddock with 2 other local M3s (Jamie) and 2 more from TN. One was my instructor, who had a space gray coupe with the Dinan stroker engine in it. Rode with him a couple of sessions. What a beast! Plus he had Dinan stage 3 suspension, Dinan exhaust, ST trophy BBK, etc. Talk about a "sleeper"! He was seriously chewing an some of the GT3s there.
09-13-2011, 05:47 PM | #16 | |
Rep 869
09-13-2011, 06:22 PM | #17 | |
Rep 5,506
09-13-2011, 06:39 PM | #18 | |
Rep 1,286
09-13-2011, 09:28 PM | #19 |
Rep 2,336
Air can get stuck in ABS pump/valves that's why BMW has a test plan on the gt1 for bleeding brakes. Just did this on a 645i u put pressure bleeder on the reservoir then run the bleeding procedure. Witch runs the ABS pump and pluses the valves a each wheel individually. Runs a couple times then tells u to move to the next wheel. Works great bt scan tool might do it not sure but having the gt1 is a huge help. You can do some awesome stuff to the old smg trans
09-13-2011, 11:45 PM | #20 |
Rep 697
I find the same with race pads. They always feel a bit soft, but firm up just fine on the track. When I put the stock pads back in the pedal is immediately firm again. Been this way with all of my cars.
Do you install the race pads in the same position in the caliper each time? If you are rotating them (which can be done for longevity) you will also experience what you are describing because the pads wear differently and may not mate completely flush with the rotor. I number my pads to keep track of where the pads are positioned. My last track day was not a TT event so I rotated my pads and it took 3 sessions to get good brake feel back. Everything you described sounds normal to me and I wouldn't worry about it. |
09-13-2011, 11:56 PM | #21 | |
Supreme Allied Commander
3843
Rep 54,362
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
07-21-2018, 10:20 PM | #22 |
Rep 744
i realize it's an old thread that i'm bumping, but I've had the same experience - swapped out what I assume were stock pads, which had a linear bite right at the top for Ferodo DS2500s, increased pedal travel immediately after. I did open the brake fluid reservoir to let out some fluid since the pistons were getting pushed back a decent bit. Right after, no braking force until a third of the way down and then it bites relatively hard.
Bed & bleed? Update - swapped the OEM pads back on, pedal firm again. Then swapped back to the Ferodos, and immediately lost that top 1/3rd firm pedal. I've no idea what the reason for this is. Last edited by kyoo; 07-23-2018 at 11:06 PM.. |
