03-08-2024, 11:22 AM | #1 |
Rep 82
03-08-2024, 12:32 PM | #2 | |
Rep 350
Take apart the pulley and spin it. You should be able to tell if there is an excessive amount of play in the bearing, does it feel gritty, is it noisy, and then be able to make a decision. From what you described as checking yourself they sound good. There needs to be a little bit of drag from the grease encapsulated in the bearing. Sometimes the grease dries out and you can get away with simply cleaning out the races and repacking with fresh grease. If you search the forum, you can order just the pulleys you need that are not expensive.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
03-08-2024, 01:24 PM | #3 |
Rep 82
Yep I ended up finding that thread afterwards and did just that. One thing I didnt take into account is the wear of the actual plastic pulleys themselves. I didnt realize they are smooth when new, and mine have some grooving. I think the bearings are fine but the wheels are probably on their way to failing.
Thanks! |
03-08-2024, 03:16 PM | #4 |
Rep 350
Yup. That grooving is most likely just typical from the reverse PS pump needing the double-serpentine belt.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
