04-16-2019, 11:17 PM | #1 |
Rep 361
VF OR ESS Supercharger
looking to get a supercharger kit for my car before summer. Stuck between VF620 and ESS 625. Id want the gintani stage X but way to expensive any input on VF or ESS?
I've personally seen the VF put more power down on the dynos consistently over ESS... any feedback would be nice! Trying to get the best bang for my buck! |
04-16-2019, 11:30 PM | #3 |
Rep 361
04-16-2019, 11:57 PM | #4 |
Rep 2,747
Power wise I'm not sure but probably negligible. I know they're the same centrifugal blower running similar boosts. Maybe the difference is in the tune? I have an ess kit sitting in the garage. I haven't installed it yet, personally I'm not really concerned about the dyno numbers more concerned about it not wrecking the motor..
Ess have sold way more kits but you can't go wrong with either If you want a vf kit vivid racing have had this one on clearance for 6 months at least. You should call them and try and get free shipping or something, it's a great deal for a new kit! https://www.vividracing.com/engineer...151575665.html
9ers
04-17-2019, 04:02 AM | #6 |
Rep 361
04-17-2019, 06:40 AM | #7 |
Rep 1,673
From what I hear air/air intercooler and rotrex style blower. Wont make anymore power on top but will increase mid-range torque to be like the evolve and aa kits. But that also means a good price increase over the vortech unit.
Electronics Junkie, Engine Builder.
08-29-2019, 12:58 PM | #8 |
Test
115
Rep 1,707
08-29-2019, 01:12 PM | #9 |
Rep 18,808
Drives: BMW
We made the move to ESS some years ago and can say ESS without a doubt. Hardware and tuning are significantly better.
Check the 60-130 thread and you'll see the standings dominated by ESS: https://www.m3post.com/forums/showthread.php?t=630463
08-29-2019, 06:08 PM | #10 |
Rep 457
VF has stopped development on the S65, ESS has better intake design and continues to develop for the S65.
SYT_Shadow11478.00 |
08-29-2019, 11:58 PM | #11 |
09 M3 e93 VF650, e30 e85, Remus, Federal’s 595rs
205
Rep 329
I’m on the same boat, I’m leaning towards the VF.
09 M3 E93 - VF650, AFD e30 e85, Remus Race, Federal’s 595 rs-pro’s.
09-05-2019, 06:26 PM | #13 | |
wannabe
252
Rep 819
I self installed my vf kit and from my experience it is completely reversible to stock as well.
E90 M3 - 6speed - slicktop - single hump
chocstraw495.50 |
09-10-2019, 10:55 AM | #14 |
Rep 1,566
VF routes the air intake pipe forward and therefore requires you to cut off an airbox mounting bracket.
09-10-2019, 11:04 AM | #15 |
Rep 1,385
both make the same power output if you go with a different tuner,
VF has better choice of injectors using the larger bosch 123 injector (57lb) vs ess using the smaller 42lb injectors that max out the fuel system. Ess has a better install as the bracket is one pc not 3 like the VF Ess manifold is more pleasing to the eye but both flowregardless. VF is easier to pick up a phone and get replacement parts. Ess you are restricted to a email. Over all after owning 3 and installing others the ess kit is a win but I would suggest picking up long tip bosch 123 injectors and custom tune from another vender.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
chocstraw495.50 |
09-10-2019, 12:52 PM | #16 | |
Rep 1,566
Any advantage to these new 123 injectors over 42lb green giants without running E85? Kawasaki00 recorded 83% duty cycle with a 650 pulley on the greens. That sounds fine to me and not maxing out the fuel system.
09-10-2019, 02:11 PM | #17 | |
Rep 1,385
The blue injectors was uses are 42 lb modified injectors as well the black injectors they sell with the 625kit are the 38lb injectors. My duty cycle may shave been higher due to the miles on my car. |
09-10-2019, 02:59 PM | #18 | |
Rep 1,566
Wish I knew about these 57lb injectors before I upgraded from the black 124 that came with my 625 kit to greens. Would've saved me the hassle of fitting the fuel rail spacers if nothing else and they don't cost much more. My car runs great with the green injectors/94mm pulley and I don't plan on running E85 so sounds like there's no point in switching now, but I appreciate the info.
09-10-2019, 07:13 PM | #19 |
wannabe
252
Rep 819
You drill out the rivets to remove the bracket. it is reattached with two m8 bolts
09-10-2019, 07:18 PM | #20 | |
wannabe
252
Rep 819
