09-29-2010, 10:12 PM | #1 |
Rep 225
How much $$$ to get H&R springs installed?
Hello,
I'll drop off my M next week for a DCT software update at the dealer. I'll have them swap out my stock springs with H&R springs, what would be a common price for this job? I guess the warranty related to all parts of the suspension will be canceled right? Thanks Alex |
10-05-2010, 03:04 PM | #3 |
Rep 225
Just talked to the dealership.
They would charge me $900 to change the springs. I said that this is a lot more than I've expected, he said it's a 7hrs. job to change the front springs alone...? What's up with that? Does it realy take 7hrs. for just the fronts? Thanks Alex |
10-05-2010, 03:26 PM | #4 |
Rep 225
Just found a DIY for aftermarket springs.
It takes 2-4 hrs to change front and rear... What's up with my dealer...? I probably will do it myself. Did anyone change the springs with only a car-jack instead of a lift? Thanks Alex |
10-05-2010, 03:53 PM | #5 |
Rep 6,912
The dealer is nuts when it comes to labor charges. It took my shop less than 2 hours to do it. Any competent shop can get it done in 3 to 4 hours MAX...with time wasted!!!
It's a pretty easy DIY, and yes a good race jack and stands is sufficient. I did Coilovers on my old M3 in my garage with no lift. A buddy to help out will definitely make life much easier though.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
10-05-2010, 05:18 PM | #6 |
Rep 9,032
It's not that hard to do, and NO WAY it should be 7hrs!! I'm surprised the dealer would even do it.
Don't forget about the alignement afterwards.
10-05-2010, 06:00 PM | #7 | |
Rep 225
thanks for your input. I'll give it a shot this weekend. Would you recomend to replace all bolts and nuts? Alex |
10-05-2010, 06:07 PM | #8 |
Rep 225
10-05-2010, 10:14 PM | #9 |
Rep 9,032
Also, you should try to get the E36 M3 front bump stops to give you a little more travel. It's what Dinan uses on their kit.
Not sure if it's recommended on the rears.
10-06-2010, 06:13 PM | #10 | |
Rep 225
Well, since this is what Dinan does I'd assume it's ok? |
10-10-2010, 12:38 AM | #11 |
Rep 9,032
Definitely do it. There are was a very nice write up here showing what Dinan uses for bump stops and how they shaved the front strut hats down.
