09-26-2010, 03:28 PM | #1 |
Rep 1,311
BBK StopTech vs. APracing--clear OEM 18" with 12mm spacer?
Ok fella's,
Times getting near where I'm gonna have to decide. I'm gonna go with 12mm spacers all around with the style 219 18" OEM wheels my M3 is fitted with. I know from what venders and others have said, APracing BBK will clear with no less than 10mm spacers so this should be no problem. Assuming the Stoptech's will clear it too...hopefully. I'd like your feedback and inputs on which BBK to go with and what pads. It looks like the Stoptech's are gonna be considerably cheeper so I'm interested in them too. Street to on/off the track without having to change pads is what I'd like. Might track about once every two months. Thanks and cheers, Rob |
09-26-2010, 07:59 PM | #2 |
Formerly K335i
19
Rep 215
Rob, as I mentioned in your other thread, StopTech's 380mm kit will *not* clear the OEM 18" wheels. You would have to go with their 355mm rotors all around if you want to stick with your wheels.
2009 E92 M3 :: Jet Black :: Fox Red Extended :: Carbon Leather :: 6MT :: JRZ RS Suspension :: RD Sport Sways :: StopTech Trophy Brakes :: Cantrell Brake Cooling |
09-26-2010, 10:21 PM | #3 |
Rep 3,157
no match AP all the way
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
09-27-2010, 01:50 AM | #4 |
Rep 9,032
OP, if you track 6 times a year, you might as well get some track wheels/tires. Then you could get the bigger BBK's out there that'll have greater thermal capacity.
Please show some solid proof of this? That's a BOLD statement.
09-27-2010, 06:55 AM | #5 | |
Rep 1,311
I'm thinking of the AP's because it'll clear the OEM 18" with 12mm spacers and for now I would not have to go getting wheels & tires. But please give some points on it. Cheers, |
09-27-2010, 11:04 AM | #6 |
chris
278
Rep 12,144
in order to fit the stoptechs, you have to go with their smaller kit which i believe is 355mm rotors all around. this is smaller than the stock oem rotors which are 360mm in the front.
ap racing's front rotors are 368mm so its a larger size than the oem rotors. this is probably why people who have 18" wheels tend to do APR brakes.
09-27-2010, 11:16 AM | #8 |
Formerly K335i
19
Rep 215
09-27-2010, 01:25 PM | #9 | |
Rep 9,032
The other issue is the AP's are Brembo prices, while the StopTech's are considerably cheaper, at least in the US.
09-27-2010, 11:28 PM | #10 |
Moderator
673
Rep 4,737
Fact 1: ST has 355x35 vs stock 360x30 for front.
Fact 2: It's not just the thermal capacity but also the rate of cooling that affect heat management. BBK discs have a much higher vane count and hence higher air flow and cooling. Fact 3: You can download a ST caliper template from http://www.stoptech.com/tech_info/ch...60-24C0-00.pdf to see if your wheels will work. Fact 4: Racing driver Leh Keen has ST on his car and never has an issue... using the "street sport" ST pads which is quiet like stock on the street. Fact 5: ST has a removable steel bridge to allow pad change w/o taking off the entire caliper. |
09-27-2010, 11:37 PM | #11 | |
chris
278
Rep 12,144
i think brembo is the only one that needs calipers removed for pad changes.
09-28-2010, 12:32 AM | #13 | |
Rep 9,032
Fact 7: When I was at JIC/Cross' US headquarter's they have StopTech's on their race cars. THAT'S why I'm still waiting on Eugene's (who's a well respected member here) reason why the AP's are CLEARLY the better system. They CLEARLY cost more; I'll give him that. They give GREAT support/info on this forum too, and it's MUCH appreciated.
09-28-2010, 12:38 AM | #14 |
Formerly K335i
19
Rep 215
Fact 8: I run StopTechs and absolutely love them - best mod for me hands down!
Fact 9: A number of senior instructors/former professionals I know run STs on their insanely fast C6 Z06s. Fact 10: Turner runs ST brakes on their race cars. Come to think of it, I see orders of magnitude more ST brake systems at track days than I do any other setup... and I've never heard a single negative review.
09-28-2010, 01:39 AM | #15 |
Rep 1,659
Sounds like StopTechs are the shizzle!
M3 E93 DCT, Space Grey,BC HB29 Forged Deep Concave Wheels, Ericsson Amuse F/R Bumper, Evolve Full Exhaust System, INTRAX Coilovers, STOPTECH BBK, Performance Steering Wheel,Custom Red/Black Leather Seats,///M3 ||Bimmerpost M3 Car Of The Month May - 2010SOLD
2010 R35 GTR |
09-28-2010, 02:33 AM | #16 | |
Rep 10,407
1. Access of unimpeded air flow to the vanes 2. Proper vane shape 3. Proper vane count Obviously if your claim was totally true you could just keep adding vanes and at some point you would have to make them thinner and thinner. Which would result in a weak rotor under the pad compression load.
09-28-2010, 09:19 AM | #17 |
chris
278
Rep 12,144
stop techs are great but the fact that they only have a 380mm or 355mm front rotor and nothing in between does not make it ideal for people who want to run 18" track wheels. the clearance that you have with the 380mm front rotor is very very minimal even if you get 18" wheels that can fit over the caliper and rotor.
for this reason, i'd still prefer the AP kit since its 368mm which is a good compromise between bigger rotors and easy fitment into most 18" wheels. it really depends what size and type of wheel you want to run for track use.
09-28-2010, 12:55 PM | #18 | |
Rep 13,583
Drives: JB E92 335i
- Alan |
09-28-2010, 01:03 PM | #19 | |
Rep 287
///M3 E90 '09 Le Mans Blue | DCT | Silver Novillo | Tech | Prem | 19"s | Prem Sound | iPod
StopTech BBK | Volk VR.G2 | H&R Sport Springs |
09-28-2010, 03:03 PM | #20 |
Rep 4,048
+1000
We've done our research on this before deciding to carry the product (in which we carry both stop tech, and AP Racing). We put AP Racing on our E92 M3 because of their major background. AP Racing has been in Formula one, and more importantly now, they're in about 85% of all NASCAR race cars. Because of their extensive background, we knew that we hit the nail on the head with this one. And because of this, we've sold several kits to forum members on this board who extensively visit the track. So far, we've had a great response and we look forward to serving more. But more importantly, if you're looking for track duty, AP Racing all the way. If you just want a set up that works well, that wont have any issues, then either one will be perfect for you. |
09-28-2010, 03:25 PM | #21 | |
Rep 1,311
Thanks to all of you guys giving inputs. I think as I go read on and collect all this info, I am with you on this Jurrian about the AP's. If I had to rank it all for what I'd want then AP's and Brembo's are at the top, Stoptech's 3rd. So what I'm looking for again is to fit a BBK with my OEM 18"s and avoid spacers if I can. I'm looking into low profile wheel weights and I hear that might be my answer in combination with Brembo 365/6pot up front. I have no hard data yet if the AP's will fit the bill along with the Brembo's for wheel clearance. Again, thank you all for the inputs. |
09-28-2010, 03:25 PM | #22 | |
Formerly K335i
19
Rep 215
But what you are doing is making a very broad and bold generalization that the AP setup is clearly superior to the ST setup for track duty, which I think is completely bogus. Where is your data? Because the anecdotal data in this thread suggests that ST is just as good... Both of these kits are top notch. Let's not make arbitrary statements otherwise.
