09-26-2010, 02:57 AM | #1 |
Rep 1,311
Change 18" to fit BBK or go 19" wheels? or just get spacers???
Hey fella's got a few questions,
So I'm pulling the trigger on eithe AP's or StopTech BBK's. Not sure yet which but 6POT front & 4POT rear. My M came with style 219 18" OEM wheels as it's a US spec M3. APR BBK require at least a 10mm spacer for the front's so it's either MS spacers 12mm or go with a bigger wheel. I'm on the fence about either getting 18" wheels that WILL clear the BBK's and keep my tires for two reasons. One, they only got like 20K miles on them. Second, I don't have a ZCP or lowered suspension and the 18" fill it up well and look good IMO. So big question is, what are my pro's and cons for going with 19"? I may not end up messing with the suspension to lower it and leave it stock. Plus I do track occasionaly and don't 18" handle that a bit better? Cheers, |
09-26-2010, 03:36 AM | #2 | |||
Formerly K335i
19
Rep 215
There are a couple of different questions here, so let's take them one by one...
I have the stock 19s that I use on the street and a separate set of 18s with track rubber. In general, I think it's best to have a separate wheel/tire combo if you track often enough; otherwise you end up severely wearing out your street tires. Since you have the stock 18s, your BBK options are more limited assuming you want to keep the stock wheels. If you don't, there are plenty of 18" options out there that will clear large front rotors and allow you to run a wide variety of rubber.
2009 E92 M3 :: Jet Black :: Fox Red Extended :: Carbon Leather :: 6MT :: JRZ RS Suspension :: RD Sport Sways :: StopTech Trophy Brakes :: Cantrell Brake Cooling |
09-26-2010, 09:15 AM | #3 |
Rep 1,311
Hey thanks for inputs,
I do like the looks and versatility of the 18" wheels like you mentioned. I'm more inclined to stay with 18"s like I originaly posted but my choice is either go with spacers for a while to clear the APR. APR's kit will clear only with no less than a 10mm spacer up front with the style 219 18" OEM wheels from what **********s and AP has told me. So that's why I'm thinking spacers but I don't trust spacers, just seems more can go wrong, especially with the stress of a track. I won't be tracking like a pro and often enough to worry to much about tire wear to be honest, at least for now with my present location and probebly in the near future will be the same frequency of track visits as now. So then, what 18" will fit the 245/35 & 265/35 18's I got now and clear the AP BBK? I'll start looking around. |
09-26-2010, 12:43 PM | #4 |
Formerly K335i
19
Rep 215
You have nothing to worry about with spacers. Quality made spacers will be just fine and can easily handle the rigors of the track. I use 12mm spacers on my track setup and they do just fine.
As for finding new 18" rims that will accept your existing tires, just look for rim widths that are similar to the stock widths (8.5 front and 9.5 rear).
09-26-2010, 03:08 PM | #5 |
Rep 1,311
Thanks for the advise man! Yeah, I don't really want to fork out $1,000 for the same size wheels but maybe in the future I will. Just a bit skeptical about the spacers but I'll take your word for it. What's the worst that can happen
I'll probebly go with 12mm to make sure I clear the BBK's. Now next big question, which brakes to get?? I might make a new post for that. Cheers, |
09-26-2010, 05:20 PM | #6 |
Rep 9,032
You can get the APEX 18" wheel and it'll clear StopTech 380mm BBK, and the spacer is optional up front. You could go 9.5" or 10" up front, and 10" or 10.5" rear or any combination of the two. That way you could get a larger rotor in up front.
The wheels are very reasonable priced. http://www.m3post.com/forums/showthr...highlight=apex For spacers, consider these. They sell them for just a little over what people are selling them used for: http://www.m3post.com/forums/showthread.php?t=372072 .
09-27-2010, 05:34 PM | #7 | |
Rep 1,311
09-27-2010, 06:05 PM | #8 |
Rep 700
Get spacers and be done with it. Car will look a bit better too!
I apologize for spelling mistakes up front, they are a result of multitasking.
09-28-2010, 03:30 PM | #9 | |
Rep 1,311
I'm all for it bro, but I got to make 100% sure what combo of BBK and spacers with my OEM 18" will work. I'd be fooked if I had it on a lift, found out the hard way all this crap ends up rubbing. You can understand? Thanks & cheers |
