09-23-2019, 08:03 PM | #1 |
Rep 872
PittRace!
Wow! Course was awesome! Elevation changes were pretty intense and video doesn't do them justice. Received the below overheating message several times and while I never hit limp mode, I'm curious how long I might have had if I wouldn't have backed off for half a lap or so and let the car cool down.
After seeing the message pop up I noticed oil temp was quite close to 300. Car cooled quickly after backing off and the message would disappear after half a lap cooling down. Of course it would come back after a hard lap. It was unseasonably warm this weekend on the east coast with temps in the low 90's.
AA Gen 2 Lvl 2 w/Meth; MagnaFlow catless x-pipe; Dinan Underdrive Pulley; VAC Coated Bearings; ARP Rod Bolts; Oil Diverter Valve; Dinan Strut Braces; Dinan Rear Toe Links; ECS Rear Trailing Arms; MCS 2-Way NR w/700F-1000R; GC Camber Plates; AKG 75D MM & 95A TM; CAE Shifter; Titan T-S5; StopTech ST60 380mm/ST40 355mm; MFactory DS; Zebulon Splitter; Zebulon 330 Rear Wing; Gutted w/Piper Motorsports Custom Cage; OMP WRC-R Seats
09-24-2019, 06:23 AM | #3 | |
Rep 872
More curious than anything else, because when that message popped up I still had full power, but backed off as a precaution. Didn't know if I was seconds away from limping or maybe if I had another lap.
09-24-2019, 07:16 AM | #4 |
///M Powered for Life
11480
Rep 10,328
Pitt Race is pretty decent, #3 in my mind after The Glen and VIR
No worries about your warning. The car will go into limp shortly after you get the warning but nothing bad has happened. I suggest you start with the cooling mods! do88, etc Remember that if you want the car to last longer you can short shift. Short shifting a supercharged car is still fast |
SonnyJack326.00 |
09-24-2019, 08:30 AM | #6 | |
Rep 872
Funny you should mention short-shifting. I was short-shifting my ass off for most of the day.
SYT_Shadow11479.50 |
09-24-2019, 08:34 AM | #7 |
Rep 872
Since I went with the DeansBimmer aluminum version it's now rock solid! I mowed a bit of grass on Saturday and lost my gt4 replica splitter (was already cracked) but nothing else moved. Had I the stock version it would have been toast for sure!
09-25-2019, 10:47 AM | #8 |
Stop the hate, get a V8
3850
Rep 8,625
I have to wonder if the aluminum under tray could cause some heat soak issues -- you have a big piece of metal (a heat sink) instead of plastic.
Past: 2011.5 M3 sedan ZCP |
09-30-2019, 07:50 PM | #9 |
Rep 872
I guess it's possible. Running Summit Point Main this weekend in much cooler temps and with little elevation change so we'll see how temps compare. Have run that track in hotter/more humid temps and never run as hot as at PittRace.
09-30-2019, 08:06 PM | #10 |
Rep 12,726
i'd be a little skeptical of that... it might get warm, but its not going to transfer or retain heat and impact cooling. i decided these aluminum trays aren't for me, but they are definitely better than nothing.
SonnyJack326.00 |
10-03-2019, 01:58 PM | #11 |
11480
Rep 10,328
I'm going back to the stock felt piece for sure
10-05-2019, 02:56 PM | #13 |
Rep 9,032
What issues do you guys have with the aluminum ones?
I'd think Turner would test theirs before selling it?? .
10-07-2019, 05:10 AM | #14 | |
Rep 872
As expected, ran SP Main this past weekend in low 60's and didn't even hit 255 degrees for oil temp. I kinda forgot how much the engine likes the cooler air!
10-07-2019, 05:13 AM | #15 |
Rep 872
No issues for me! A previous poster mentioned that maybe the aluminum undertrays acted as a heat sink and thus attracted and retained heat, leading to increased engine temps. Anything is possible, but I'm not going back.
aus891.50 |
