03-25-2018, 09:58 AM | #1 |
Rep 764
Drives: M3 E90 Jetblack
anybody using Ground Control Articulating height adjuster?
I purchased the GC articulating perch as it came highly recommend by Bimmerworld. my installer tried putting them on with a 9" swift spring in the rear and it seems there isn't enough adjustment for such a long spring. for those of you that have this perch, what size spring are you running?
I don't think it matters but the dampers are 1WNR MCS.
check out my YouTube feature film:
03-25-2018, 12:12 PM | #2 |
Rep 10,613
I have the Rogue version on my E36. Screwed all the way down like a normal spring perch they obviously have no room to articulate. You probably need 1 inch shorter springs than you would use with normal perches.
03-25-2018, 12:26 PM | #3 |
Rep 764
are there issues with running a different brand spring in the rear but with the right spring rates? I'm able to source eibach rear springs locally in 7 or 8 inches but my fronts are swift springs
03-25-2018, 01:52 PM | #4 |
Rep 10,613
I am not a spring expert but as long as they are the same diameter and rated at the weight per inch you want they should work (Swift may rate in metric but you can do the math to find the closest in a lbs/inch rated brand. The experts debate weight and wire type and thickness and coil bind and each thinks one brand has advantages over another. Eibach is good, Swift is good. You can order Swift online and get them in a few days if in stock.
03-26-2018, 03:05 PM | #5 |
Rep 764
Updating this thread in case people search for this same exact issue in the future.
Turns out that the GC articulating rear height adjusters can be cut (they were designed that way) for cars that need to go lower. I spoke to Trevor @ Ground Control to verify this. Even though 8" rear springs are the preferred size, 9" will fit if you cut the rod. The only reason why I went with 9" springs was because it was recommended by Bimmerworld. I got in touch with my sales guy today and he acknowledged that I should have got 8" and the initial recommendation was a mistake. Not really making an effort to make it right. Instead, he countered with selling me a brand new set of springs which isn't really making it right. A bit disappointing given their reputation but it is what it is. My installer will be cutting the height adjusters today and hopefully all is solved. Moral of the story: If you get the GC Articulating Rear Height Adjuster - get a 8" spring If you get an older-style height adjuster, a 9" spring is fine. |
JustAnothaM4883.50 |
03-26-2018, 04:05 PM | #6 | |
Rep 357
Even though I had a great experience with BW and will be purchasing and consulting with them again in the future; I personally wouldn't let it go. Can't shrug it off and say my bad sold you a WHOLE 1 inch longer spring and not fix the issue as a company. Speak to a manager or someone else I'm sure BW wouldn't want this to be representative of how they deal with errors. |
03-28-2018, 08:51 PM | #7 | |
Rep 764
03-28-2018, 09:25 PM | #8 |
Rep 10,613
The salesman did not really understand how what he was selling works. That is unfortunate. Sometimes when I deal with Bavauto, the salesman will read from a comments section presumably made up of comments learned from customers, users, etc. I have added to those comments before when I returned products that dud not work or had issues. Hopefully Bimmerworld has something similar so it can better serve the next guy and not lose customers. A salesman can’t know how all products work on all cars.
04-09-2018, 06:12 AM | #9 |
Rep 1,261
Drives: 2016 M4 GTS
Please keep in mind the GC articulating perch is for a "race" application. You may need to do maintenance on the ball bearing inside every now and then so they function correctly.
2016 M4 GTS Alpine White
2021 X5M Competition Marina Bay Blue Instagram: @JustAnothaM4 |
05-06-2018, 12:43 PM | #10 | |
Rep 293
Do you have helper spring in the rear?
05-06-2018, 12:44 PM | #11 | ||
Rep 764
05-06-2018, 12:57 PM | #12 |
Rep 293
06-28-2020, 05:58 PM | #13 |
Rep 1,055
Bumping old thread to get experience feedback from those running these, have you experienced any downsides?
Thinking of picking these up because I dont like how my springs sit, particularly the right side which doesnt sit as vertically as the left. This lack of symetery between the two sides I would think causes the springs to behave differently between the two sides. I'm hoping these would help the springs maintain proper alignment for proper loading. |
07-10-2020, 12:48 PM | #14 |
Rep 327
They work fine. They make a little noise once they break in, just a light noise/rattle over small bumps. I had to cut them down, which is expected for running 8" springs with reasonably high rates. Adjusting them is extremely easy, by far the biggest advantage of this adjuster.
Chris
07-12-2020, 08:50 PM | #15 | |
Rep 1,055
Thank you, I went ahead and ordered a pair, just have to get around to installing them.
aFe Stage 2 Intake | BW Race X-Pipe | UUC Corsa Exhaust | Alpine MS Tune | Brembo GT
07-13-2020, 08:42 AM | #16 | |
Rep 1,027
I have them on my car and can also say ease of adjustment is amazing. With 800lb rear springs I have no issues getting mine down to basically no tire/fender gap. That said, I could foresee moving to 850 or 900lb springs in the future.
Steve::::2012 AW E92::::IG - @sjs0433
07-13-2020, 02:20 PM | #17 |
Derbo Tuning
3609
Rep 3,022
I missed this thread, but I cut my thread rod for 9" springs in the rear too. the GC adjusters had instructors to cut if necessary on a piece of paper.
IG:ruhrohz_m3
07-13-2020, 07:59 PM | #18 | |
Rep 327
Chris
07-19-2020, 12:37 AM | #20 | |
Rep 1,055
I will be using a 1000 lb spring, sounds like you had to cut for the 8" but 7" just fits after cutting them?
I'd rather get a spring length that doesnt require I cut the rod. Quote:
07-22-2020, 02:01 PM | #21 | ||
Rep 867
As far as the weight jack itself is concerned its a really clever system. Height adjustment is super easy and cutting the rod was simple. I used a hand saw and vice and filed it smooth. Took maybe 30 minutes to get done. I can't think of a single way they can be improved, it's a great product. |
M43S7RO503.00 |
10-22-2020, 06:33 PM | #22 | |||
Rep 2,967
Bump... For an 8" spring - does rod need to be cut? how much? Are you all running helpers in rear? If not, what sits between bottom rear spring and camber arm? |
