12-30-2015, 04:25 AM | #1 |
Rep 134
FS: Weller WFE P/ WFE 2P 2-operator soldering tip fume extractor ZERO SMOG [NEW]
Made in Germany, brand new in box Weller FT Zero Smog WFE2P 2-operator smog/vapor/smoke fume extractor. This industrial grade tip extraction unit includes: (1) main unit (2) F7 class fine particulate air filter (3) main filter consisting of class III particulate filter & gas filter (50% activated carbon, 50% Purafil) (4) mains cable (5) operating instructions booklet (6) safety information booklet (7) registration card (8) final inspection statement (9) poly bag with three additional F7 pre-filters (10) poly bag with lock bolt extension This Weller WFE2P (120VAC) is a fume extraction device for one or two soldering irons. The unit is best suited to continuous industrial operation in the workplace due to its maintenance-free pump drive and low noise generation. A built-in thermal cut-out protects the unit against overload. A built-in lifting device for changing the filters allows trouble-free replacement of the filter cartridge and preliminary filters without the aid of tools. ~Self-contained bench-top fume extraction unit ~No external air source required ~Capacity for up to two WellerŪ fume extraction irons / stations ~Reduces harmful soldering emissions from the source ~Extracts 99.99% of fumes before they can be released into environment ~Efficient four-stage replaceable filter system ~F7 grade fine dust pre-filter ~Main filter consisting of a wide band gas filter (50% active carbon and 50% puratex) and a HEPA class 13 fine particle filter ~Silent running, maintenance-free pump for extended continuous service ~Compact size uses minimal bench space and allows portability ~For use with Weller FE series fume extraction soldering irons (can work with other tip extraction units from Hakko, JBC, and others) ~UL and cUL listed, OSHA compliant ~For fume extraction at the tip of the soldering iron ~Operates with 120VAC Weight: 4 kg / 8.82 lb Height: 295 mm / 11.6 in Diameter: 140 mm / 5.5 in Sound level: <45 db @ 1 m distance Last edited by Halitosis; 10-24-2017 at 09:47 AM.. |
