      11-28-2020, 01:24 PM   #1
exVtekGuy
Drives: none yet
PS reservoir cap replacement
Can anyone tell me the correct part number for power steering reservoir cap with gasket? It seems bmw parts only shows the complete reservoir assembly available but browsing the internet, the caps used for other cars may fit. The part i found is 32416851332..
      11-29-2020, 11:50 PM   #2
TX
Drives: 2009 ///M3 E92 APW 6MT
According to ECS, this one does fit the e9x m3.
If you want the BMW branded cap:
https://www.ecstuning.com/b-genuine-...s/32416851332/
ZF for cheap:
https://www.ecstuning.com/b-zf-parts...2416851332~zf/
It looks like you might also need gasket part #ES1306711 with that.
The MFR # is 32416851332 for the cap.
However, FCP says it doesn't fit so who knows.
ECS has been wrong in the past so apologies ahead of time if so.
      11-30-2020, 01:48 PM   #3
wyatth
Drives: E90 ZCP
Or just get the gasket/seal itself since your cap is probably fine. That's what I did recently and it's kept the exterior of the cap a little dryer.
PN 32411128333
      11-30-2020, 03:38 PM   #4
exVtekGuy
Drives: none yet
PN 32411128333
thanks will do. i might get that ps reservoir extender IND sells also. Seems like that works too fix the leak.
      11-30-2020, 04:50 PM   #5
wyatth
Drives: E90 ZCP
The 3Ddesign piece? Skip it.
If you're just on the street, get a new seal (PN above) and a reservoir sock (search Amazon, I did plain black so it doesn't show).
If you track, get the overflow DIY fix with the OE Brembo reservoir, tubing, etc. Cheap and effective.
