      03-02-2014, 03:53 PM   #1
Lbsigman
This is my sham shield.
Lbsigman's Avatar
61
Drives: 2020 M2
Loose fitting AFE Pro Dry air filter. Video inside.
Bought one for my '04 Silverado 2500HD with the 6.0 and that one fit perfect. Then again it's just a standard rectangular type air filter.
The other one is for my '13 E92 with only 3,800 miles on the ticker. I'm really not thrilled with the fit of the filter so I did put the factory one back on.
The tension button is working as it should. The factory filter does not budge as the foam is softer yet the structure seems to be more rigid with the plastic skeleton inside. The AFE filter lacks this and I think the polyurethane type material is too hard to get a good seal.
What do you guys think? Sorry for the jittery video, I was trying to record the video, hold a flashlight, and move the filter at the same time.
      03-02-2014, 03:58 PM   #2
The Nash
Drives: 2010 M3; 2006 325xi
Did you use the correct one for your MY, I am using the exact same filter and mine fits so tightly you can't move it at all.
2010- 13
2008-09
      03-02-2014, 04:01 PM   #3
W///
W///'s Avatar
7736
Drives: F82GTS, E36/E92M3, Z4M
You are positive you've got the right model? I had the correct filter and after about 8000 miles, the flat surface that the spring rests on deformed I think, not forming a tight seal. It wasn't as loose as yours, but enough to throw mine away and get an AA filter (which the backing is much more solid)
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      03-02-2014, 04:02 PM   #4
Lbsigman
Lbsigman's Avatar
61
Drives: 2020 M2
2010- 13
Attachment 985939
2008-09
Attachment 985940
Yup. The part number I used is 11-10119.
Look identical to this:
      03-02-2014, 04:06 PM   #5
Lbsigman
Lbsigman's Avatar
61
Drives: 2020 M2
Nice filter, I just don't care for the oiled type.
