02-24-2014, 03:36 PM | #1 |
Rep 4,319
Replacing oil pan, replace bearings?
I've got to get my oil pan replaced and was wondering since they are pulling it if I should preemptively replace the rod bearings? I've been doing Blackstone reports for the last few changes with no noticeable issues. Just considering the bearings since it is so involved / expensive to drop and replace the pan. Can they inspect them without removing each bearing? I assume no, but again wanted to check.
BTW, pray that you don't need to ever replace the pan. Getting quoted 8-10 hours of labor + the pan itself (which is $950-1100 + core! )
GT3 RS | Desperately seeking the next great M car...
02-24-2014, 03:49 PM | #2 |
Rep 241
Drives: 2011 E93 M3
Is your oil cracked, or is the drain plug stripped. My drain plug was stripped. Used a Time Sert kit to repair it. Worked great.
2013 F10 M5/TTFS CUSTOM TUNE/PURE S1 TURBOS/METH/AMS CL DPS/RPI CATBACK/KW SLEEVE OVERS/RPK FRONT LIP/M PERF REAR SPOILER/20" LOMA SUPERTEC SUPERLIGHTS
02-24-2014, 04:45 PM | #3 | |
Rep 19,002
Drives: BMW
02-24-2014, 04:55 PM | #4 |
Rep 12,405
If you are paying that much labor already, might as well bite the bullet and do the bearings IMHO. Then the S65 should be good for a while
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
02-24-2014, 05:03 PM | #5 |
Rep 3,633
I dunno; doing a pan is much less labor intensive than bearings and it's still a bigger job to go; and your reports are fine, why fix what ain't broke?
02-24-2014, 08:42 PM | #6 |
Rep 454
Drives: :O
02-24-2014, 09:14 PM | #7 |
Rep 4,319
My results have looked okay thus far, hence my dilemma. I can have the tech inspect them but don't think they will see much unless they remove the bearings, right? Never seen it done so just wondering what is possible.
02-24-2014, 09:15 PM | #8 |
Rep 4,319
Did you have to drop the pan to do this? Assume so.
02-25-2014, 09:05 AM | #10 |
Rep 241
Drives: 2011 E93 M3
Absolutely not, just put the car on a lift, drain the oil. It only took maybe five minutes to do the job. Very easy, did it myself. Access to a lift makes it a lot easier. There are a few youtube clips you can watch first.
02-25-2014, 09:54 AM | #11 |
Rep 4,319
How do you ensure no shavings from drilling it don't stay in the pan? Will try and find some videos to watch. Thanks.
02-25-2014, 11:13 AM | #12 |
Rep 3,633
02-25-2014, 12:16 PM | #13 |
Rep 241
Drives: 2011 E93 M3
Exactly, I used bearing grease on mine to catch the shavings.
03-03-2014, 04:47 PM | #14 |
Rep 4,319
Just a quick update. Proceeded with a replacement of the pan. Visual inspection was good per my SA plus got the updated Blackstone report from my last change below. All levels look good so leaving well enough alone for now. Knock on wood.
03-03-2014, 07:01 PM | #16 |
Rep 10,407
I agree with those saying don't bother. You've got great oil reports and assuming no audible signs of bottom end problems, save your money. It's hard not to be swayed by the contingent here saying that every S65 is a bearing time bomb waiting to explode... So indeed don't waste money on oil reports if you are going to completely ignore them. Good luck.
03-03-2014, 07:06 PM | #17 |
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
^ This
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
03-03-2014, 07:57 PM | #18 |
Rep 7,479
If you read enough on BITOG, you'll come to distrust UOA as a measure of engine health. Better than nothing, but it's real intention is to tell you how the oil is doing.
03-03-2014, 08:01 PM | #19 | |
Rep 4,319
I believe I may benefit from having most of my miles at highway speeds and full operating temps. Hopefully future reports have consistent results.
03-04-2014, 03:23 PM | #21 |
Rep 4,319
Looks like a nice simple job
Should have just done this at home with some ramps...
03-04-2014, 03:46 PM | #22 |
Stop the hate, get a V8
3858
Rep 8,625
Correct, it's a better indication of how a particular oil is holding up for your situation (driving style, specific motor, etc).
Past: 2011.5 M3 sedan ZCP |
