07-14-2021, 01:41 PM | #1 |
Rep 285
E92 alpine white trunk fs
OEM E92 M3 Alpine White trunk Drilled for GTS wing base. Base Plate holes are 30 inches apart. No shipping located in Socal
IG: lowkey_domm
08-10-2021, 06:27 PM | #5 |
Rep 571
Ugh... I'm thinking hard about this.
Is this an LCI trunk (as in no key hole)? Also, it looks like the back hole is a little off... does that affect the install at all? Finally, can you post install pics from different angles? |
08-11-2021, 10:57 AM | #6 | |
Rep 285
I believe you're referring to the wing mount holes on the trunk, they're not perfect because I went from a GTS wing to a GT4 on the same trunk so I had to notch the hole some more. Does not affect install cause you'll use either washers or backing plate for your wing and the base plate hides the holes so you cannot see the holes from outside.
IG: lowkey_domm
Tags |
e92, trunk |
