09-16-2019, 08:01 PM | #1 |
Rep 460
AFE Dry Air Filter on '08 *review*
This will be short.
Not a complex upgrade, if it is even an upgrade. Basically it is a drop-in replacement for the OE filter, except unlike the OE filter, it is not reinforced on either end making it not seem to provide a good seal. The pressure of the plastic thumb on the opposite end of the filter from the opening is enough to warp the filter slightly. To add insult to injury, the opening of the filter is soft enough that it never feels like it mates solidly to the plastic mouth of the intake. As for the actual results of the install? Well I haven't dynoed the car but I honestly can't tell a difference. The car might be very slightly louder from induction noise, but nothing dramatic. As for power, too little if any gain to feel. I didn't pay much for the filter, but I still think it is a waste of money on the S65 unless you get a killer deal. Last edited by GtiGyver; 09-16-2019 at 08:19 PM.. |
09-16-2019, 08:15 PM | #2 |
Rep 460
I want to add that this is the ONLY filter I tried other than the OE unit.
I don't know if the design of competing products is any different from AFE's design for the S65. |
09-17-2019, 10:07 AM | #3 |
Rep 181
I have the Active Autowerke green performance filter for my 08 E90. The quality is very high, definitely more solid than the oem filter.
There is a very noticeable increase in induction sound, which I like. I can't feel any real difference in power (don't have a baseline dyno with the oem filter so I couldn't even compare the two on paper). My oem filter needed replacement anyway and I figured for $100 I can swap in a better quality filter from AA that makes the car sound better, may net some performance gains (on paper), and can be cleaned and reused so that I won't have to purchase a replacement filter ever. To me, that last part alone is worth the $, just my two cents.
2008 E90 M3 - Sparkling Graphite Metallic / DCT / slicktop / single hump
09-17-2019, 10:50 AM | #4 |
Rep 1,930
The induction sound alone was worth the upgrade to me. The fins do get a little bit warped but it's not bad. Paired with the M-performance exhaust, sound so good.
09-17-2019, 11:08 AM | #5 | |
Rep 460
The AFE I installed clearly was not reinforced. The silicone ends have lots of give and warp under the pressure of the mounting spring. Maybe my model is older. |
09-17-2019, 12:53 PM | #6 |
Rep 1,069
I went with the BMC filter. Solid fit, not flimsy feeling at all. A nice noticable increase in induction sound. Very happy with quality and fitment.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus |
09-20-2019, 12:35 PM | #7 | ||
Rep 181
12-16-2021, 02:29 AM | #8 | |
Rep 32
12-16-2021, 02:57 AM | #9 | |
Rep 7,106
Edit: Apparently, but the other way around as you have an 08: https://www.m3post.com/forums/showth...filter+adapter Last edited by Helmsman; 12-16-2021 at 03:06 AM.. |
12-16-2021, 05:50 PM | #10 | |
Rep 32
My issue with the AFE filter is that the back part seems so soft that when it’s installed the nipple doesn’t seem to push hard enough for the intake mouth to seal. Visually though, it seems sealed. One of the pictures is me pushing in the back part with little effort. Another is where I pull up slightly on the filter and will expose the leak. The old mahle filter back is rock solid as OP says. I might be thinking too much on it, but I t’s probably how the product is made. I might be returning it if the seal leak will be an issue. Thoughts?
12-16-2021, 07:12 PM | #11 | |
Rep 3,001
INSTAGRAM: GORDON.M3
12-17-2021, 02:10 AM | #12 | |
Rep 7,106
12-17-2021, 06:47 PM | #13 | |
Rep 32
I’ll probably keep it as is lol it’s probably not a big deal anyway. Maybe I am overthinking things haha
