10-25-2017, 11:24 PM | #1 |
Rep 18
Recommended Paint Brand for DIY with Paint 688 Jet Black?
As title suggests, does anyone know what's the recommended brand for Jet Black 668 paint? I'd been quoted $200 to painting a small trim piece, which I bought new and came with Primer on it. This trim is to replace a crack piece on my e93 roof. So I'm thinking to try DIY.
I googled 668 and I came across this. Anyone has experience with this and how it blends with remaining color of the car? https://www.amazon.com/Dupli-Color-B.../dp/B004TBOGPG Thanks all, Last edited by ioric18; 10-26-2017 at 01:07 PM.. |
10-26-2017, 07:55 AM | #2 |
Rep 93
You probably won't find many on here who will recommend a single stage gloss black paint for jerez. Since it's a small trim piece, it's understandable that the $200 sounds high, but from a shop perspective the effort in the job isn't going to be much less than a single panel.
Unless there is a single stage Jerez out there somewhere, you'll need to have it painted and then cleared with actual Jerez Black paint. As far as brands go, PPG is always my go-to. |
10-26-2017, 09:57 AM | #3 |
Rep 18
Thank you for the reply.
I looked up PPG, and seems like they carry A73 Jerez black. Is that the right paint code? Also, can you help elaborate what you mean by "clear it by Jerez Black"? Doing this for the 1st time, so appreciate any wise words (or DIY link) from all the experts out there. Thanks again. |
10-26-2017, 12:20 PM | #4 |
Rep 93
If you're using multi-stage paint, you'll have a Jerez Black base coat and then you'll have to spray a clear coat over the top. If you use a single stage like a gloss paint in a spray can, you don't need the clear coat over it. I'm not sure about the paint code selection, but any PPG vendor should be able to look it up for you without trouble.
Unless you find it in an aerosol spray can, it does require equipment like a spray gun and compressor. |
10-26-2017, 12:39 PM | #5 |
Rep 1,932
Drives: 2013 E92 M3
A73 is the BMW code for Jerez Black, 668 is Jet Black....solid non metallic black.
10-26-2017, 05:28 PM | #6 |
Rep 18
Thanks for the clarification.
I looked up the sticker under my hood and saw 688, so yes, I will need Jet Black paint, not A73 Jerez Black. (My bad) I found a few helpful DIY links below: 1) http://www.m3post.com/forums/showthr...ight=DIY+paint 2) Since the part is already primed from BMW, I'll do the following: 1) Wash and wipe it clean/dry 2) Spray 1st layer of paint, wait 5-10min before 2nd/3rd paint 3) Apple coat 3~5 times, depends on finish condition. 4) Wet Sand with 2000 grit 5) Compound, then Polish to remove orange peel off Anything missing from the above steps? |
10-27-2017, 05:56 AM | #7 |
Rep 2,907
Drives: 2011 E93 M3
If you're seriously considering actually painting an M3 roof trim with a spray can to then just follow the instructions on the can. In my experience, Duplicolor paints don't last. In a year you'll notice it looks like crap compared to OEM.
You can make it look good for a while if you are a painter, but if you have to ask about the steps involved, odds are the results are not going to look good and you're going to spend a day futzing around with it. What's your time worth? Pay a shop the nominal $200 to have it done right with the proper materials. |
