02-23-2020, 03:08 AM | #1 |
Rep 87
ESS 625 second idler pulley question
Hi folks,
I wan putting my ESS kit on and when putting the idler pulley onto the bracket, I realized that in the manual there wasn't a detailed description for how to assemble that. I've stored the kit for a while and moved the parts around some times so I'm also not sure if I have everything needed for the pulleys. If anyone has any insight it would be super helpful! Thanks in advance! Attached picture is everything I can find for the pulleys. Not so sure if the silver ring should be 1 or 2 |
02-23-2020, 03:12 AM | #2 |
Rep 87
A little update:
I put the silver ring onto the top pulley and it made the pulley spinable (without the ring it would be stuck). BUT the top pulley and bottom pulley wouldn't be on the same horizontal level, hence belt couldn't be routed. Does that mean there must be a second silver ring for the lower pulley as well? I assemble the top one in the order of: bracket, spacer, silver ring, pulley. Not sure if it's the right way but it seems to work? Any input is welcome! |
02-23-2020, 03:29 PM | #4 |
Enthusiast
117
Rep 150
The ring is definitely the Bypass valve ring. Look at the video at 4:00
If you have the gen 1 bracket take a look at ESS website below if it helps with a reference on how the pulleys go in. https://esstuning.com/e9xm3-sc-brack...bly/#gallery-1 https://esstuning.com/e9xm3-sc-brack...bly/#gallery-2 If you have a gen 2, here is mine where I'm trying to resolve the touching issue. You can reference of how the spacers go below the pulley. Also here is the PDF manual if it helps. Keep us updated!
02-23-2020, 03:49 PM | #5 | |
Rep 87
02-23-2020, 03:54 PM | #6 |
Enthusiast
117
Rep 150
Both pulleys should spin freely when installed. I am removing the belt ad supercharger pulley on Thursday and will let you know if you don't get it resolved by that time.
02-23-2020, 04:02 PM | #7 |
Rep 87
