04-07-2020, 08:07 AM | #1 |
Rep 634
Drives: 2012 Space Grey e92 M3 ZCP
Preventative Maintenance Throttle Actuator Gear Replacement
I saw that gavsadler went ahead and replaced his throttle actuator gears preventatively before any codes were thrown using a kit similar to this: https://www.ebay.com/itm/2X-New-Thro....c100677.m4598
I'm curious if anyone else has done so. Is this a better solution than waiting for the car to enter limp mode and replacing the entire throttle actuator? Obviously significantly less money. I'm curious if this prevents the circuit board from frying as appears to be the case with letting the gears wear and fixing once it's already broken. Is there a certain mile marker that the actuators begin to fail? |
04-07-2020, 10:13 AM | #2 |
Rep 113
Replace the whole unit with OEM thru FCP EURO lifetime warranty and be done.
Hard to determine which will go out first. The gears or circuit board? Who knows? Wastes time going back and forth trying to find what went wrong. These units are known to fail so just replace them. I replaced both at the same time for peace of mind but that's me. |
roastbeef11584.50 |
04-07-2020, 10:25 AM | #4 |
Rep 10,614
Or use MPower Motorsports, which has UK Rebuild units with rebuilt electronics as well as new gears. As someone who replaced gears in 4 actuators, I don’t recommend replacing just the gears. I now have one actuator I bought new and one from MPower.
04-07-2020, 10:30 AM | #5 |
///M Powered for Life
11480
Rep 10,328
I preemptively changed both of mine to the M Power versions
04-08-2020, 12:33 PM | #7 |
Rep 634
Thanks everyone for the feedback. Sounds like paying the $700 for the M Power rebuilt units is the general consensus.
04-08-2020, 07:03 PM | #8 |
Rep 1,230
04-09-2020, 07:29 AM | #9 | |
Rep 787
I guess the subject was much discussed before, but the question is inevitable: do the worn gears cause some "overload" in the circuit board and then its failure? I think it's because you don't want it to happen in a road trip or anywhere far from home, cause it will ruin your fun. |
04-09-2020, 08:28 AM | #10 |
Rep 10,614
Look up the posts by Jason or read at Ukrebuild.org for info on what he does. Probably someone who is good at electronics could also repair or improve boards.
Someone who pays $400 for a HPDE or goes on a long trip in his fun car would want to be reassured his car would perform well. But if you don’t care, you will still be able to do 80 on level ground and could drive for thousands of miles. |
SYT_Shadow11479.50 jvictormp881.00 |
04-09-2020, 09:34 AM | #11 | |
Rep 634
04-09-2020, 09:35 AM | #12 |
Rep 634
04-09-2020, 09:42 AM | #13 | |
11480
Rep 10,328
Some people do not want to risk it for many reasons |
04-09-2020, 09:43 AM | #14 | |
11480
Rep 10,328
People have replaced gears and had them fail anyway. Removing the plenum is some work and I don't like doing work twice. First time right is the way to go! |
Space Fox1042.00 |
04-09-2020, 09:57 AM | #15 |
Rep 787
04-09-2020, 09:59 AM | #16 | |
11480
Rep 10,328
I have two E9X M3s. One has 60k and that one is getting preventative M Power actuators. The other has 39k and will keep its actuators for a while more |
jvictormp881.00 |
04-09-2020, 10:53 AM | #17 |
Rep 5,483
My car has original actuators at 126,000 miles. Probably because I have a pair of new ones in a cabinet - the ol reverse Murphy’s law. If I have to go in there, ERRYTHANG is getting replaced. I have just about all the plastic stuff in the vee ready to go in a cabinet if anything fails but so far, nothing has.
So my advice because of my one anecdote is don’t bother unless you’re going to be in there anyway for another job. |
04-09-2020, 12:28 PM | #19 | |
Rep 10,614
Since any original actuators are now 7-12 years old, my recommendation to most people is to wait until one fails and then replace both. But I think you should replace the gears in yours since you are not convinced. It might cost you $100 and take a day, but you will feel like you tried. |
04-09-2020, 12:33 PM | #20 | |
Rep 634
04-09-2020, 12:59 PM | #21 | |
11480
Rep 10,328
not doing things twice is a good way to not screw up
04-09-2020, 02:07 PM | #22 |
Rep 10,614
If you want to have even more fun, I think someone on eBay is selling strips of replacement mosfets for these actuators. You will get good at pulling the plenum after you have removed it a dozen times. You will probably also break a plastic hose or hose connector or wire harness holder or connector or forget to connect something during one of your removals or reinstallations.
