12-20-2017, 04:59 PM | #1 |
Rep 29
Battery size question
I have a 2010 e92 m3. It is time to change the battery. I opened the trunk and found that my current battery is an autozone duralast T8-DLG. Group size T8-LBN5-93. Funny thing is that auto zone says this battery does not fit my car. And I have search everywhere says I should be using an H8 battery. So should I be finding an T8 or H8 battery now?
12-20-2017, 05:41 PM | #2 | |
Rep 1,867
12-20-2017, 07:54 PM | #4 |
Rep 29
Makes me wonder why I have been using a T8 battery... I plan to get an H8 battery installed then drive home to code it myself. May be a 5-6 miles drive. Will I have a problem? Or should it bring the battery home and install it myself then code it right away.
12-20-2017, 08:02 PM | #5 | |
Rep 3,726
Drives: 2018 M2
Be careful using car matched battery suggestions mine came up as an H6 but the one in there was a much bigger H8. I believe the three battery sizes are due to the options installed in the car. More options require more battery power so think about it. Also H6 is about 70aH down from about 90aH from an H8 so won’t power as long with the engine not running. Also you’ll need to recode the battery if its more than a 10aH difference. What are you going to code it with? Carly doesn’t work and I’ve heard schwaben doesn’t either Also it’s odd you have a 2010 and are about to be on your third battery already Last edited by EJT86; 12-20-2017 at 08:10 PM.. |
12-20-2017, 08:14 PM | #6 |
Rep 3,726
Drives: 2018 M2
There’s three different battery sizes that are factory installed. You should replace it with whatever size you have now, unless you’re dead set on weight savings which comes with consequences
12-20-2017, 10:16 PM | #8 |
Rep 3,726
Drives: 2018 M2
12-20-2017, 11:49 PM | #9 |
Rep 1,867
12-21-2017, 06:25 AM | #10 |
Rep 10,610
12-21-2017, 02:56 PM | #11 | |
Rep 3,726
Drives: 2018 M2
i thought you were saying there was someway to do it in idrive or something like resetting the oil interval after a change |
12-27-2017, 06:21 AM | #18 |
Rep 3,726
Drives: 2018 M2
12-27-2017, 11:00 AM | #20 |
Rep 3,726
Drives: 2018 M2
well ive only had mine in for about a week. Bosch/Exide are OEM suppliers so theres some M3s that came out of the factory with that very same battery. other than finding a cheap place to have it registered properly its fine so far. my rear defrost has come back to life and its started right up today at 10 degrees this morning. i got mine for $130 so it was an obvious choice for me. plus i think the Bosch H8 is about 5-6lbs lighter
12-30-2017, 11:25 AM | #21 | |
Rep 1,178
12-30-2017, 11:52 AM | #22 |
Rep 10,610
Mine came from Pep Boys but other places probably carry them also. And the same battery is probably sold under other names. Pretty much all batteries are made by 2 companies. Johnson Controls and Exide. Probably all AGM H8s are very comparable.
