04-29-2023, 07:50 AM | #1 |
Rep 2,907
Drives: 2011 E93 M3
Custom rear subframe assembly, all new and upgraded
This is a fully assembled and upgraded rear subframe assembly for any 08-13 M3. This was built for a custom job that didn't get seen through. All the parts are new or restored, vapor honed, etc. for a consistent appearance. Rather than disassembling it and putting each part back in inventory I wanted to offer it to the group at fair pricing (not a fire sale). Restoring the rear end of these cars makes a wonderful difference in how the car behaves, especially on-track. This assembly is available as-is, but I can also modify this package to your requirements if you want a custom system built to spec, ready to bolt-in. Sample costs noted in parentheses below. -Subframe stripped and titanium Cerakote applied (more durable than PC, won't chip) ($400+core) -Turner Motorsport solid Delrin/aluminum subframe bushings ($620) -Powerflex Purple front & rear differential mounts ($200) -New OE Control arms, lower arms vapor honed ($2000~) -ECS aluminum trailing arms, vapor honed ($320) -Fall Line Motorsport toe arms ($600) -Fall Line Motorsport Sway bar end links ($280) -Hotchkiss adjustable sway bar set (front and rear), stripped, PC'd in silver. ($600) -Genuine BMW axles, (new/remanufactured by BMW). ($3000) -Knuckles restored as new w/new bearings ($300+cores) -OE hubs w/ 14mm Titanium studs, all new parking brake components, parking brake cables, sensors. ($600) Asking $4900 for the assembly as pictured above without differential. A differential is not included in the package price but can also be available in stock form or fully renewed with a Wavetrac or OS-Giken LSD built to your spec. Freight shipping is available if required. Installation and setup in our McKinney, Texas shop Mporium BMW is also available. |
05-20-2023, 03:13 PM | #3 |
Rep 2,907
Drives: 2011 E93 M3
Still have this in its assembled form. Would love to see this go to a good home as-is. For anyone able to come to our shop in DFW, TEXAS, we'd be happy to install this and setup your suspension.
06-24-2023, 02:49 PM | #6 |
Rep 2,907
Drives: 2011 E93 M3
To the top. It's about time to dismantle it if no takers.
06-27-2023, 10:21 AM | #9 |
Rep 1,292
I’m def interested in the subframe if you’re willing to separate. I would take the whole assembly if I wasn’t in Canada. Freight shipping will cost too much to get that across the border unfortunately.
