08-02-2018, 10:09 AM | #1 |
Rep 979
Strange exhaust noise/vibration during heavy rain
Hey folks,
Since supercharging the car, an odd issue comes up only when it rains really heavily and I am driving on a flat road. All of a sudden, I will hear a heavier exhaust noise, and when I modulate the throttle the higher the rps, the louder and more guttural the noise. In addition to the noise, i get a very odd vibration that resonates in the cabin under the driver footwell into the seat and drivetrain. As soon as I hit a hill or a decline, the noise clears. Its like water is getting into the intake somewhere and getting off flat surfaces helps it roll off. Im pretty low suspension wise so I often wonder if that contributes to the water getting in somewhere. I also have an AFE 2 stage with the induction port closed(snorkle to hood vent) to reduce the SC whine. I have a harrop supercharger so the whine you hear is not related to the issue. Its also raining like a mother so hard to hear over that. I tried to capture in the below video but its not great. It happens right at 5 seconds on the below video. https://drive.google.com/open?id=1TM...dyS_6NguYIw16j Anyone had something like this? Think its doing any harm?
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... Last edited by Mvy; 08-02-2018 at 11:13 AM.. |
08-03-2018, 09:19 AM | #3 |
Rep 162
Hard to discern the noise since there is no "dry" example, but I have a couple thoughts.
Does it sound like your cold start air pump is on again? I had mine randomly come on during last winter when driving (oil & water were at std temp). It was very obvious. I never identified a cause. Do you have a P3 gauge or Awron? I recommend comparing AFR and ignition timing from dry driving to wet driving. Very rich and very lean conditions can cause audible changes in your exhaust tone. Same with ignition timing.
2009 E90 M3 DCT
08-03-2018, 09:33 AM | #4 | |
Rep 979
Its similar to cold start roughness, but only when pushing the throttle. Its so weird it only happens when it rains very heavily and at no other time. Its happened about 3 times now. The amount of vibration is much worse than typical cold start however and the fact it resolves when getting off flat makes me think its not the pump. I dont have a p3 or awron but I do have carly. Can I check with that?
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... Last edited by Mvy; 08-03-2018 at 10:09 AM.. |
08-03-2018, 10:46 AM | #5 | |
Driver
2692
Rep 2,714
Mvy540.50 |
08-03-2018, 11:07 AM | #6 |
Stop the hate, get a V8
3850
Rep 8,625
If the car is stationary in the rain, does it happen when you apply constant throttle? This would rule out certain portions of the drivetrain causing the problem.
Past: 2011.5 M3 sedan ZCP |
Mvy540.50 |
08-03-2018, 01:53 PM | #7 |
Rep 979
Yes. When i noticed the sound, I pulled over still on flat. When applying constant throttle, the volume and amount of vibration increases exponentially.As soon as i get off level ground, it goes away in an instant.
08-03-2018, 02:32 PM | #8 |
3850
Rep 8,625
Does it happen after you wash the car?
08-03-2018, 05:12 PM | #10 |
Rep 979
same here. I can't make it happen with a hose. I've tried flooding a bunch of spots. it's almost like I have to drive through high water ( an inch or two on the road) to get it to happen.
09-10-2018, 01:56 PM | #11 |
Rep 979
Final Update:
I believe this issue is related to the center support bearing. I just replaced it. My suspicion is water was getting up into the drive train somehow triggering the terrible vibration I was experiencing. Ill post updates if it comes back, but so far so good.
11-25-2018, 05:39 AM | #12 |
Rep 979
Ugg its back. Left at the shop, they could not find anything wrong. And of course the heavy rain stopped as soon as I dropped the car off. Its a mystery.
11-25-2018, 01:02 PM | #13 | |
Rep 979
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... Last edited by Mvy; 11-25-2018 at 01:26 PM.. |
05-19-2021, 12:36 PM | #15 |
Rep 19
You have an exhaust leak somewhere. S65 decel compression pulls air/moisture into your o2 sensors and takes a minute to correct
Gregonater1.50 |
01-30-2023, 04:26 PM | #17 |
Rep 979
I did actually. Two things. I went back to the stock airbox. Next, I had blocked my hood vent (drivers side) to reduce my supercharger noise. It actually acts as a place for the intake to eject water when its raining. I see tons of water come out of it in the rain. Once I pulled that foam blocker I had made and put in there out, I have not had the issue since. Even in heavy rain. So that seems to have been it. If you have an aftermarket intake, or your vent blocked, this could be the problem.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... Last edited by Mvy; 01-30-2023 at 04:33 PM.. |
01-30-2023, 06:46 PM | #18 |
Rep 1,691
intake is just eating up rain water, you can alleviate the issue by just adding a rain sock over the filter.
