08-29-2019, 12:01 AM | #1 |
Rep 591
Driver sider undertray came loose
Hi All,
I drove to a plaza that I have never been to. The bumps turned out to be slightly higher than the other places. When I passed it, I can hear the bump scratching/pushing on the undertray. On my way home, I sort of heard loss screw kind of dangling sound. I managed to drive home slowly. I looked under afterward, it seems to me something on the driver side came loose. If I push the area where driver side meets center piece, there is about half inch play. It cannot go up further, but I did not dare to pull down. The passenger side is solid and no play. If I looked up the diagrams, the only thing holds that area is Bowden cable unit (#24). The part seems to be clipped onto somewhere underneath. But when I pushed up, I can feel solid resistance like hitting a block. A loose cable should not do that. I wonder if anyone who has opened up the belly can help to figure out what might be broken? I live in condo so no direct access to lift/jack (not even allowed). I want to try to find out what is broken and just order the parts before going to shop. (When I looked under, I noticed the few screws that holds bumpers are not there. Probably were gone when I bought from last owner earlier this year. Can anyone point out the part# for the bumper screws too?) thanks Last edited by romero1990; 08-29-2019 at 09:56 AM.. Reason: fix video |
08-29-2019, 02:04 AM | #3 | |
Rep 591
thx. do you think the top of the cable can come undone if it got pushed hard from the bottom? After looking at a few YouTube video, the area should be like my passenger side, no play up/down. I probably should tear the area up entirely. Last time the car went into shop, the mechanics found a big bolt fell/caught by the under tray. Last edited by romero1990; 08-29-2019 at 09:56 AM.. Reason: remove double quote |
08-29-2019, 06:00 AM | #6 |
Rep 11,061
The front felt undertrays are usually badly damaged on any of these cars that have been driven. Particularly the side wings. Not cheap but replacement wings are available, as is the center tray. Deansbimmer sells a flat aluminum plate replacement that is more durable and won’t scrape itself to pieces over a few years.
08-29-2019, 07:47 AM | #7 |
Rep 3,781
Drives: 2018 M2
It’s only held on by the two cables, and clips that you screw it into. The new clips suck and end up tearing the felt which might be why you’re missing some. You don’t NEED a jack or jack stands, find a curb to straddle maybe in a park or lot. BUT I’ll tell you this, the treys are so fragile, and since it sounds like you haven’t been under there in a while, there’s a good chance it’s been broken for a while you just didn’t know it. So now that you do know there’s not much of a need to treat it like a huge deal, just my advice. If it’s a broken cable I have two extras from my old trey
08-29-2019, 09:38 AM | #9 | |
Rep 591
08-29-2019, 09:44 AM | #10 | |
Rep 591
08-29-2019, 09:45 AM | #11 |
Rep 591
just realized the video embedding did not work. fix it to show what's up down there.
08-29-2019, 11:08 AM | #12 |
Rep 848
I'm about to go with the deans Bimmer one
deansbimmer3941.00 |
08-29-2019, 11:27 AM | #13 |
///Majestic
1872
Rep 2,093
There is an extremely easy solution to this... I wouldn't get the solid belly tray because i have heard that it can be dangerous when hitting things with such a solid piece. The hit needs to be absorbed somehow and if it's a solid piece the body of the car will take the shock.
The felt on the other hand is soft so it's suppose to do its job and take the damage. What's the solution you ask? Well I just recently changed both left and right wings and the center front belly tray for roughly 500 dollars from FCP euro. And with there life time warranty on everything if it gets damaged I'll order another one and return my damaged one and get my money refunded. Easy. |
08-29-2019, 11:30 AM | #14 |
Rep 591
08-29-2019, 01:45 PM | #15 | |
Rep 7,206
08-29-2019, 02:57 PM | #16 | ||
///Majestic
1872
Rep 2,093
The sellers excuse was his dad stalled it and the lip went over a bump stop in a parking spot and when he reversed it took the pan and side shields with it |
08-29-2019, 09:20 PM | #17 |
Rep 591
after watching a video on how to uninstall the belly pan, I think the cable nut might be unhooked from the clip when the belly pan got pushed up really hard. The video uploader almost just slided the nut to one side and gave a push. Well, I probably should not speculate more but find a time/place to take it off and see what happened
08-29-2019, 10:31 PM | #18 | |
Rep 848
I wonder if deansbimmer has ever commented on this. |
08-29-2019, 10:37 PM | #19 | |
Rep 3,781
Drives: 2018 M2
08-30-2019, 12:57 AM | #20 |
Lord Scrip
1861
Rep 3,050
Drives: 2011 M3 Coupe
Go back to that same speed bump and drive fast. Jk, you will become veeeeery familiar with the 3 little assholes under the bumper. The world is on a mission to destroy the 3 little assholes under our front bumpers. You will learn to look ahead and predict moronically performed maneuvers by other motorists and avoid their debris if it is 3 cubic inches or greater or you will lose your 3 little assholes under our front bumper. Welcome brother!
08-30-2019, 01:38 AM | #21 | |
Rep 591
I managed to raise the coilover to like 2 inches off ground. The bothering part is all 3 parts are physically lower than the front bumper. Like BMW build it so we can screw it up. |
08-30-2019, 02:36 AM | #22 | ||
Lord Scrip
1861
Rep 3,050
