08-25-2008, 11:32 AM | #1 |
Rep 363
KERS, coming to a BMW road car near you!!!
Dont know where I read this but I just remembered it. If any of you are F1 fans then you know that thanks to Bernie and Max F1 teams now are making the optional KERS system for their cars. Apparently they were supposed to come to F1 for the 2009 season, but due to development issues its massivly delayed. At STR the KERS system set the factory on fire, and at BMW it electricuted one of the engineers and sent him flying backward 30 feet LOL
With that said, BMW or somone at BMW said that they want to bring this system to BMW road cars. Anyone think this is maybe a bad idea? LOL F1 cars havent even had success with it. They are having problems storing the energy in compact hyper capacitors, the system discharges violently (which can be a problem for the driver and anyone near the car). What if one crashes? the crash crews at F1 races could get electricuted, and the driver as well. I think this is amusing, the system may very well be the future (or maybe not) but at this point it just seems like a good way to kill your F1 drivers and your customers LOL now who would like KERS on their F30 M3???? LOL |
08-25-2008, 11:36 AM | #2 | |
Rep 4,021
Drives: 2008 335xi Coupe
We had a good debate on this on a couple of threads where I proposed they had to use big capacitors instead of batteries (since batteries are very inefficient). I hope BMW ///M uses KERs....if they don't and they go with turbocharging, they are going to lose a lot of customers like me. KERs was the one hope that would allow BMW to make a turbo engine behave like a naturally aspirated engine.
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
08-25-2008, 01:01 PM | #4 |
Rep 10,407
That ^ says the system is using flywheels to store the energy. Obviously this is consistent with the "K" in the acronym for Kinetic. Don't see anything about capacitors...
08-25-2008, 01:09 PM | #5 | |
Rep 4,021
I came up with the capacitor "idea". To goal of KERs to get around the weight inefficiencies of batteries. Also the limitations of battery based hybrids are the charging and discharge rates..... There was an article that said F1 was indeed working on electric systems so my best guess was they would use super big capacitors instead of batteries since this was the only known technology that has the desired charging / discharge rates. I seem to recall the F1 system was supposed to deliver 50 hp over a few seconds and weigh something like 50 kg....this is well beyond any battery technology that we know of today. Chicagobimmerboy's post seems to confirm BMW is heading off in this direction of using capacitors instead of inefficient batteriers. BTW, KERs should also really help with braking performance
08-25-2008, 01:18 PM | #6 | ||
Rep 8,017
I know I touched on this a while ago but since it been brought up again I thought I should provide the link.
http://www.torotrak.com/ (Check the 'What's New' section as well as the rest, interesting reading for geeks.) Quote:
08-25-2008, 01:35 PM | #7 | |
Rep 4,021
Yes.... The only notable difference is Southlight brought up F1 using electrical and not mechanical based KERs systesm.... If it is electrical it seems it is likely they will use capacitors instead of batteries.
08-25-2008, 01:43 PM | #8 |
Moderator / European Editor
1545
Rep 6,754
Like T says, BMW Motorsport is using an electric KERS and not an mechanical one like developed by Torotrack. I don't know which F1 team will be using mechanical KERS. Any information on that, Footie?
The problem in Jerez was caused by "capacitive coupling". In case anybody is interested in some more details here's a statement: http://www.press.bmwgroup.com/pressc...uesmann-ef.doc BTW: Only a "small amount of energy" was transferred, so the mechanic wasn't in danger at all, nor was he "flying backwards 30ft". No need to be pathetic here. Best regards, south
08-25-2008, 01:47 PM | #9 |
Rep 8,017
I haven't a clue but they do have two teams on board and one is a major one.
Sorry I should have worded this better, one is a front runner (don't know which) and the other is just behind. |
08-25-2008, 01:53 PM | #10 | |
Rep 4,021
Thanks South! This is a very minor issue that would necessarily get fixed in production cars since they go through much more rigorous safety testing. The issue was essentially stored energy from the KERs system "bleeding" on the normal 12V bus that controls all the other car's electronics. I think the production level issues will be something like:
08-25-2008, 02:16 PM | #11 |
Rep 1,108
In my latest Roundel machine, there is a small article on KERS and the F1 BMW Sauber team which indeed specifically states they will use big capacitors instead of batteries for efficiency purposes. And since the car is already 50 kg under the normal wieght limit with the current balast, the additional weight of the equipment and capacitors will not be an issue.
08-25-2008, 03:58 PM | #12 | |
Rep 10,407
Guys, I am still confused the article link posted by Ersin says,
08-25-2008, 04:11 PM | #13 | |
1545
Rep 6,754
Best regards, south
08-25-2008, 04:45 PM | #14 | |
Rep 4,021
Bastards they stole my idea! I wonder if we will see grounding straps in the production cars....BMW will give it some wierd long German name but it would be just a metal strap to dissipate power....
08-25-2008, 06:38 PM | #15 |
Rep 735
Unless you are tracking your cars, how would you benefit from KERS? As far as I am concern, the energy stored in braking is only good for abt 50 extra ponies for 7-8 secs a lap, and they brake alot in F1. Honestly, how often do you slow your M3 from 190 to 45?
Current: BMW F32 435iA M-Sports; BMW E92 M3, M-DCT; Mercedes W221 S550 4matic; Ford Fiesta ST; Nissan Silvia S15 Spec-R Retired: BMW E93 323iA; BMW E85 Z4 3.0i, SMG; Lexus IS 250 AWD; Lexus GX 470; Mercedes W203 C230 Sportscoupe; Peugeot 206 S16; Peugeot 206 RC |
08-25-2008, 06:53 PM | #16 | |
Rep 4,021
KERS would benefit road cars in performance, driveability and fuel economy.
08-26-2008, 06:36 AM | #17 |
Rep 15
To answer the question above, Williams is the only known constructor who will be using a mechanical KERS system for next year.
The teething problems that the F1 teams are experiencing at the moment are not un-common to any new technology introduced to a formula race class. Anyone who thinks KERS is some wacko space aged technology, only needs to look at road cars which are on the market right NOW that use exactly the same principles in terms of electrical regeneration systems. The actual KERS regulations in F1 for 2009 are actually very restrictive in the amount of energy that can be stored but this will progressively be increased in year intervals. Where F1 will push the boundaries with this technology starting from next year will be in the weight, packaging, cooling and reliability of these systems in racing conditions with high amounts of charging and discharging and keeping this safe in the event of high G maneuvers and impacts. This is a huge engineering challenge the teams have to overcome, and the aspects such as low weight and tight packaging will be directly transferable to road cars. F1 is a dangerous sport by nature, in fact there is far more energy being stored in an f1 fuel tank than there will be with a KERS system for next year but as has been seen through persistence and engineering on fuel tanks they are no longer an issue as they were sadly in the old days. With today’s unprecedented level of engineering and technical ability of the teams, i have no doubt that the system will have the bugs ironed out and will be safe before any team releases it into the track. And to T bone in 2013 the draft regulations propose F1 engines moving to 1.5L v6's with twin turbo chargers with two forms of energy recovery. From the turbos which would be a constant recovery system, as well as the energy recovery from brakes, that will be seen next year. They are expecting to produce over 200kw of power just from Recovery systems, power which would have otherwise been ‘wasted’. Awesome technology and no doubt for marketing reasons to align themselves with F1, M cars will also have a form of KERS and turbochargers. Prepare yourselves for that new wave of M car. |
08-26-2008, 07:40 AM | #18 |
Ground Pilot
41
Rep 548
Drives: e92 BMW M3
I am not worried with the direction M is going with the M3. I can see great progress from the e36 to the e46 and even more progress on the e9X.
"The laws of physics cannot be repealed, even with DSC." - BMW Owner's Manual
08-26-2008, 10:38 AM | #19 | |
Rep 735
08-26-2008, 10:49 AM | #20 | |
1545
Rep 6,754
Best regards, south
08-26-2008, 11:17 AM | #21 | ||
Rep 4,021
Thanks for your post...very informative! I think you contributed another part of the puzzle...I was not aware the 2013 regs allowed turbo charging....this would explain BMW ///M's branch into turbocharging. Some fun speculation here....assuming they wouldn't try to get energy from the turbo compressors since this would adversely affect turbo lag....it seems there is lots of energy to be had on the wastegate side.... The new F1 cars are going to sound very funny and farty. Quote:
More likely energy recovery from the flywheel / coasting versus braking since road cars don't brake that much. Battery based Hybrids are extremely inefficient because of the mechanical to electric to mechanical cycle.....and of course, the ability of battery to charge and discharge quickly.... I wonder what type of capacitor technology they are going to use....or new battery technology. This is neat. Maybe I haven't lost faith in ///M yet.
08-26-2008, 11:36 AM | #22 |
1545
Rep 6,754
