07-23-2019, 12:46 AM | #1 |
Rep 51
Can't find DSC module is NSC Expert
So, my problem is the following - I'm trying to do the mph to kph conversion on the cruise control speed displaying. I did the VO coding and that is ok, but when I try to change the two values in the DSC module, I can't find such module in the NSC Expert! It's an LCI '92 M3 2011 and the only module that is similar to that is the M3DSC, which has like 5 functions in it and neither of them is the two I'm looking for... Any help would be appreciated! I can post a list of the modules I have, but I think I went trough ALL of them and they did not contain what I'm looking for.
07-23-2019, 05:47 AM | #3 | |
Rep 51
I coded both the CAS and the NFRM modules with FA_WRITE after that to import those VO codes in them. But I should also do these two: Dsc module C0C_V_EINHEIT Wert_00 ---> km/h Wert_01 ---> mls C0C_SETZ_V_MAX Wert_01 ---> km/h wert_02 ---> mls The problem is, that when I press "Process ECU" and the list with the differen t modules comes on, there isn't a DSC module in the list only M3DSC which is not the one I need, because there is like 10 functions in it. I read that sometime it's called BDSC, but I don't have that either... The question is, WHERE IS MY DSC MODULE? |
07-23-2019, 12:20 PM | #4 | ||
Rep 780
Alexand3r60.00 |
