07-09-2019, 09:08 AM | #1 |
To Punish and Enslave
33
Rep 243
Drives: with both hands on the wheel
Changed the spark plugs
Recently changed the plugs, roughly 80k miles since they were changed last.
Edit: fixed pic link |
07-09-2019, 10:48 AM | #2 |
Rep 2,138
Drives: 2011 E92 M3
Prolly best to not do that again... (not sure if the attached image shows up - highlights the 37K mile spark plug change interval recommendation from BMW)
Car run better now?
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... Last edited by Scharbag; 07-09-2019 at 01:59 PM.. |
07-09-2019, 12:24 PM | #3 |
Rep 702
07-09-2019, 12:37 PM | #4 |
33
Rep 243
I purchased the car a month ago w/ 132k miles. I have all the service records from the previous 3 owners, and the last time they were done was around 80k miles ago. I’m going through and replacing various wear parts while I wait for my Rod bearing kit (the BE spec’d Rod bolts are on back order). Might do the rear diff fluid this weekend while I continue to wait.
Scharbag2620.50 |
07-09-2019, 01:19 PM | #5 |
Rep 3,726
Drives: 2018 M2
07-10-2019, 07:58 AM | #9 |
33
Rep 243
I had only put about 200 miles on the car before I changed the plugs. No misfires or codes thrown. I didn't get enough seat time in this car to notice a difference in how it ran as I've been taking it easy until I can get the Rod Bearings done. The only reason why I changed them is because I could see from the service records that it has been a long time and I know these cars like to have new plugs. Glad I did, I've never had plugs look this bad.
08-23-2019, 11:44 PM | #10 |
Rep 285
Just found this post exactly what I needed to see. Mine has 87k miles supposing never been replaced.. do you have OEM part number by chance? How difficult of a job was it 1-10? I’ve got all the tools besides the coil pack removal tool.
08-24-2019, 07:58 AM | #13 | |
Rep 933
Drives: E90 M3
Also, I saw a lot of DIYs that have you take off the plenum which isn't necessary. |
08-24-2019, 12:26 PM | #15 | |
Rep 457
Just the intake elbow (+airbox for better clearance). I used a coat hanger and had it done in 45 mins. |
Bimmer Barney1250.00 Scharbag2620.50 |
