05-18-2019, 06:20 AM | #1 |
Rep 998
X-pipe dilemma
Hi all
My car has a Borla ATAK catback which, imo, gives off a great V8 tone. Nice bassy rumble at cruising speeds and then it quiets down in the higher revs. In my search to make the car a bit louder I just added a Remus H-pipe which kept the primary cats in place but eliminated the secondary cats and resonators. The Remus pipe is one of the less popular mid pipes/x-pipes out there so I was taking a bit of a gamble on it. My hope was that it would enhance the tone of the ATAK without being too overbearing. So I’ve had it one for a week now and it is fairly obnoxious. Sounds like a nascar at low speeds and cruising, almost like a cammed hot rod. Worst of all it has so much rasp at high rpms it sounds like a tommy gun going off. It’s actually embarrassing when merging onto a highway or accelerating in any meaningful way. I could almost deal with the low speed nascar sound but the brutal rasp when getting on it is not sustainable. Now I know just removing it and going back to the stock x-pipe will be too quiet so I am thinking of either modifying the Remus h-pipe by installing some resonators (so my setup would be primary cats and some resonators, effectively only deleting the secondary cats) or modifying my stock x-pipe to delete the resonators only thereby having the primary and secondary cats only. My question is which reduces high rpm rasp more, the secondary cats or the resonators? I have searched and seen contradictory info. Thanks!
Current: 718 GT4 6MT, F87 M2 6MT, F30 330xi, F25 xdrive35i Gone: E82 128i M-Sport, 997.2 911, B8.5 S5, 987.2 Cayman, W211 E550, E92 M3, B8.5 S4, 981 Cayman, E82 128i, E46 M3, Z4MC, Mk5 GTI VR6, MZ3R, C5 Z06, B5 S4, Volvo T-5R, Volvo 740Ti
05-18-2019, 07:19 AM | #2 |
///M Powered for Life
11469
Rep 10,328
Add resonators
05-18-2019, 10:37 AM | #3 |
Rep 656
I was in a similar position. I had the ATAK on my e92 m3 by itself. Loved the sound. I then put on a quad resonated catless xpipe. It sounded decent but too loud overall and therefore I decided to sell the ATAK and get the bomiz valved rear section.
Doesn't help you much as I didn't find a solution where I could keep the ATAK but just accepted that I needed to get rid of it. |
05-19-2019, 11:23 AM | #4 | |
Rep 998
05-19-2019, 01:09 PM | #5 |
Rep 656
The resonators are what remove the rasp. Just cutting out the secondary cats at a muffler shop and welding straight pipes in probably would have been what you wanted. Retain the resonators and the borla atak would just be a bit louder.
05-19-2019, 02:55 PM | #6 |
Rep 1,036
I would add resonators to the Remus but if you don't want to hack it up, secondary car delete is probably what you're looking for.
FWIW, I did a resonator delete on my stock x pipe with M Performance Exhaust and it sounded pretty good but had a lot of rasp when getting on it. I since then installed test pipes and the combination of that with the resonator delete was too loud and raspy. I put the resonators back in and it is perfect IMO. Less rasp but similar volume to the resonator delete.
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
