09-22-2022, 10:38 PM | #1 |
Rep 62
How do I know if I got screwed on labor at a shop?
Apologize for this post being vague because I don't know if the shop owner is on here, but I got a few things done on my car at a local bmw shop the other day and got billed a pretty large amount (at least I had thought so). There was no hours spent, no rate per hour, just a flat $$ amount on the bill. I had no intention of disputing this kind of stuff on the spot, but the amount was a bit shocking to me. The one thing that was listed was that the oil change was $320 and it's usually 220 when I take it to EAS (155 materials, 55 labor, 10 tax). Can I PM someone my bill to get an opinion?
09-23-2022, 11:02 AM | #5 |
Rep 2,012
just post the bill and black out the identifying bits
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
09-23-2022, 11:10 AM | #6 |
Rep 443
Drives: '11 E93 M3 6MT, '08 E92 335Xi
As a a comparison, my Indy charged me $239.45 for the oil change on my M3. The $239 included a Blackstone Labs oil analysis
Labor: perform oil service 0.30 hrs @$145hr = $43.50 Blackstone Oil Analysis = $30.00 Parts: Oil Filter Kit w/ O-Ring 1 @ $31.79 = $31.79 Motor Oil 10W-60 RaceTec 8.8L @$13.62 = $119.8 hope this helps!
Pete
09-23-2022, 11:37 AM | #7 |
Astronaut
514
Rep 732
Call the shop out, who cares? It's not like you're bashing them. You're just a concerned customer.
If they aren't practicing standard business practices, calling them out will prevent other enthusiast on getting screwed over too. Keep them accountable.
Instagram | @undisclosedm3
"Never think that you are above taking out the trash." |
09-23-2022, 11:57 AM | #8 | |
Rep 132
Davisca4552207.50 |
09-23-2022, 06:43 PM | #9 |
Rep 651
Drives: 2008 Melbourne Red M3 Coupe
For what its worth, I know that my local BMW Dealer charges over $300 for an oil change. They have charged this for years. In fact, I think a full oil service is now closer to $500 with the big run up in expenses the last couple of years.
09-24-2022, 10:35 PM | #10 | ||
Rep 865
If I can do the work, I absolutely will. If I don't know how to do a particular job, then I search here and on YouTube. Yes, there are great shops that do great work, but NOBODY loves my car more than I do.
Chris, 2008 E92 |
spammysammich1582.00 wyatth3548.50 |
09-25-2022, 04:36 PM | #11 |
Rep 836
Drives: Jerez E92 M3 ZCP "12"
I paid $475.00 plus tax for an oil change on my wife's 2021 E450 sedan...which included checking air pressure on all tires, tire rotations, top off all liquids.....lol...a long list of useless itemize ways to charge us when materials was probably only $150.00 if that....and it probably took the mechanic less than an hour to do the job. Oh well, sometimes we simply pay just to avoid DIY... I don't mind working on my E92, but lately been too busy to even do my own oil change. lol
chief208.00 |
09-25-2022, 06:23 PM | #12 |
Rep 1,692
i mean... lets see
$127 oil change kit? ok $30 oil analysis? ok Labor rate? probably charged you the full hour if their labor rate is $193 per hour lol. most shops will do that, some BMW dealers might, they for sure don't charge half an hour. gotta keep in mind, your car is hot af. so they probably charge that .5hr to let it cool down on their lift, then .5hr to change the oil. indy shop? probably boned you, id just expose them. to be honest, some shops are charging $220 flat for oil changes w/ everything in socal
09-27-2022, 10:42 AM | #13 |
Merlin
474
Rep 730
Drives: 2012 BMW M3 6MT w/ZCP
Greetings,
Here is my take on the dealer and Indy shops: I still take my M3 to the dealer, it has low miles and the dealer has done 'good will' repair aka no-charge repairs in the past. This occurred when I had documented one of the headlights having some condensation, at the time the car was under warranty still. The SA said he would (and did) add the issue with condensation being present to the notes in the service history of the car. Fast forward about a year later, and the driver's side headlight was having serious condensation issues. I had brought with me OEM service bulletins about this with me, and shared this with the SA at the time, in the end after they tried changing the ballast, controllers, and HID bulbs, none of those things helped - they went full bore and replaced both right and left headlight assemblies - everything - the guy comes over and said well, it would be $6,200 for the repair, but since you had this documented prior in the service notes and have BMW TSB's about the issue we're going to goodwill the charges. He said the one thing they could not goodwill was the labor, so I ended up paying out of pocket about $560 for labor - which I was fine with to have two completely new headlights, ballasts, controllers, HID bulbs, etc. - For those wondering, some of the headlight assemblies from the factory can be prone to warping or not sealing at the seams, that was the issue. Sometimes it pays to have the leverage of the dealer and their resources to get a positive outcome for you the customer, not always - but I did with that issue. Now, my (2) 335i's I take to a great Indy shop in downtown Portland, called DynaSport. They are all BMW and Mini aficionados and lovers of all stuff BMW - great, great place. Cheers, Merlin
2012 E92 M3 ZCP | 2008 E90 335xi | 2008 E90 335i | |
chief208.00 |
10-03-2022, 08:51 PM | #14 |
Rep 62
Here it is:
View post on imgur.com |
10-03-2022, 09:29 PM | #15 | |
Rep 3,408
The most complex part is the pulleys, but I guess an hour of work. It's a single bolt and disconnect and the fan pulls out. Then you can access the idle and tension pulleys. They're each literally a bolt… Fuck this shop. For context, you can install a supercharger in 10 hours.
10-03-2022, 10:11 PM | #16 | |
Rep 62
10-03-2022, 10:49 PM | #17 | ||
Rep 3,408
Original Response: I think 1 hour oil change, 2 hours tops on the pulleys, and 1 hour on the bulbs / "check tire pressures, hood shocks, etc is more than sufficient. Again, the fact that it's not itemized labor is bullshit. If they're incompetent than at least prove where they struggled. Unfortunately, it'll be an uphill battle. Other than to aggressively voice your displeasure and disclosure you're sharing the full invoice on the respective forums, and social media. There is a trove of information for 95% of DIY maintenance on this forum. Get a basic set of metric sockets, wrenches and torque wrench as you can do everything to this car with a little bit of patient and gusto. Strongly recommend to avoid these situations in the future. Good luck!
10-03-2022, 11:12 PM | #18 |
Rep 3,408
@togepi I updated my last response. Seems like they quoted the bulk of the repair up front?
10-03-2022, 11:52 PM | #19 | ||
Rep 865
I've removed my supercharger kit and installed all the stock parts, including spark plugs and fuel injectors, in 5 hours. Another 2ish hours to swap the exhaust.
Chris, 2008 E92 |
DRLane3988.50 |
10-04-2022, 12:35 AM | #20 | |
Rep 2,824
Seems like OP got hosed, all of that sounds extremely marked up. Let us know what the shop says. Last edited by wyatth; 10-04-2022 at 12:42 AM.. |
Davisca4552207.50 DRLane3988.50 |
10-04-2022, 03:31 AM | #21 | |
Rep 62
I will attempt to get some money back and give an update |
DRLane3988.50 |
