11-06-2021, 03:33 PM | #2 |
Lord Scrip
1815
Rep 3,013
Drives: 2011 M3 Coupe
So I am fighting 27B0 secondary air system bank 1 error myself. I've replaced both EGR valves and the suction hose but the error persists. I am going to swap my front O2's between bank 1 & 2 and see if I get bank 2 error now. If so I'll just replace both front O2's. That might be your issue and I would recommend swapping O2's to alleviate your 27B0 error. As far as your build up on some of the plugs, I would suggest you should replace the rubber rings on your plug tubes when you get the valve covers done. Also inspect the plug tubes for cracks as they are plastic. I think oil is leaking in and fouling your spark. This could contribute to the 27B0 as the combustion is probably low leading to bad sensor readings caused by incomplete combustion. Start off sorting your plug tubes though because that's a bigger issue that can damage the cylinder walls if too much oil gets in frequently. 27B0 won't damage the engine just mess up smog. Good luck and report back
11-06-2021, 05:15 PM | #3 | |
Rep 876
You can buy a Bosch O2 sensors on Amazon for $75. |
11-06-2021, 07:20 PM | #4 |
Rep 4,167
Try removing the entire intake system including the plenum and starting the car. Under normal conditions it should idle and drive smoothly without the plenum but will give a CEL relating to idle air control. If your car runs fine without the intake, possibly its an air leak somewhere.
I was also fighting misfire issues recently related to intake air leak (all cylinder misfire). Once I solved the leak, I found out that the prolonged misfiring had damaged the O2 sensors causing the engine to randomly hiccup/stumble under load. Replaced the O2's and solved that. Just fyi. |
11-06-2021, 07:22 PM | #5 | ||
Lord Scrip
1815
Rep 3,013
11-06-2021, 07:23 PM | #6 |
Rep 553
I think this is the rear
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 And this is front(Before Cat) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Double-check front and rear part numbers, I just looked in my past orders
Daily: 2010 Venza
Grocery Getter: 16 Q50 Red Sport Track: Top Gear or Grand Tour Concealed Weapon: 11 BMW e92 M3 DCT ESS G1 |
DrFerry6728.50 InnerBlueSkies1092.50 |
11-07-2021, 08:10 AM | #7 |
Rep 1,288
how many miles on your car?
Could also be injector or clogged cat in addition to everything mentioned above. Lots of things to inspect or try changing, but bmw ista is your best bet to help pinpoint the issue. Try your local forum to find somebody who has it and willing to help. |
11-09-2021, 02:00 PM | #9 |
Rep 2,672
Just wanted to mention that replacing the upstream O2 sensors worked wonders for my car (slightly different code set though) - LINK
DrFerry6728.50 |
11-12-2021, 09:13 PM | #11 | |
Rep 1,106
sorry to hear about your engine problems. How long did you have the injector fault showing up? |
11-12-2021, 11:46 PM | #12 |
Rep 1,106
Scary, good luck on the rebuild. try to stay positive.
11-13-2021, 06:58 AM | #13 |
Old guy
308
Rep 266
Do this before you replace the motor. Change the injector and take the spark plug out of that cylinder. Remove fuel pump fuse (#70 I think). Crank the engine to get the fuel out of the intake runner and cylinder. Change oil and filter. Put fuse back in. Pour a straw full of ATF in the cylinder. Put spark plug back in and crank it up. It is going to smoke and idle like crap. See if you can hold idle to at least 1k rpm’s and feel for vibrations and listen for odd noises. If you didn’t get any vibrations, go and DRIVE THE PISS OUT OF IT. Sometimes the piston rings need to expand back in place and will give low compression numbers. I got lucky 2 weeks ago when I had the same issue.
11-14-2021, 05:53 PM | #14 |
Rep 4,167
Jvictormp had the exact same problem. Cylinder #5 injector stuck open, hydrolocked. He thought he got away lucky, but 2 yrs and 7k kms later the rod snapped and blew a hole in the block.
https://www.m3post.com/forums/showthread.php?t=1851485 What's the mileage on your car? These injector stuck open stories seem to be popping up more regularly, even in the UK forums. I wonder if fuel quality has anything to do with it. |
11-15-2021, 04:47 PM | #15 |
Old guy
308
Rep 266
If your rod is bent you will know it by vibrations and also the sound of a rod bearing. Unless you bent the hell out of it (and if you did you would have a hole by now), 58 psi for compression seems too low.
Tags |
276e, 2b61, 37b0, clutch slipping, fuel breather valve, misfire |
