03-30-2012, 03:47 PM | #1 |
Rep 571
Drives: 640i Gran Coupe
PSS on ZCP widest size?
I've searched but can't find a answer for my exact set up. According to tire rack the PSS' in 265/30/19 have a OD of 25.3" on a 9.5" rim and 295/30/19 OD of 26" on a 10.5" rim. I've read that on average a change of .5" in the with of the rim will add/subtract .2" to the OD. That would make the 265= 25.5" OD & 295= 26.2" OD on ZCP's and only a .1" difference between the OD's of the stock Conti CS3's.
Would I be able to run the PSS 265/30/19 & PSS 295/30/19 on ZCP wheels w/ stock suspension without rub? Would I have to pull the pins up front to get more camber? |
03-30-2012, 04:09 PM | #3 |
Rep 571
03-30-2012, 04:23 PM | #4 | |
Rep 1,672
After my GC kit it was lowered even more and rubs a bit at full lock. |
03-30-2012, 05:25 PM | #5 |
Rep 571
Nice! Just to confirm... you ran PSS 275/30 & 295/30 on a completely stock ZCP suspension without any issues or rubbing? Do you recommend I pull the pins or is that not necessary?
03-30-2012, 07:13 PM | #6 |
Rep 1,672
I pulled pins to reduce shoulder wear from track. If you're not tracking it's probably not needed. even with pins pulled and camber maxed out it wasn't enough for me on track
03-30-2012, 07:14 PM | #7 | |
Rep 3,964
Dave
03-30-2012, 07:17 PM | #8 |
Rep 1,672
Actually the read rubbed just a slight bit at full compression with 295/30/19 PSS's It was very slight and shaved off just a tad bit of the outside shoulder. Shaved isn't the right word - more like rubbed off a little bit of rubber.
