03-21-2020, 12:48 AM | #1 |
Rep 431
An official E9x E85 thread
The subject of running E85 on turbo'd M's are plentiful, ie the F80 forums. However the search function doesn't yield much feedback on running E85 on our E9x platform, specifically NA applications.
I wanted to start a thread (or revive the subject) for our platform in hopes of sharing experiences, challenges/risks, downfalls and benefits running E85. I've participated in this years group buy for Alex's Alpine tune and opted for the E85 map in addition to 91. Being here in NorCal it's decently available and have had amazing results on my turbo E36, I figure why not. |
03-21-2020, 03:42 PM | #2 |
Rep 298
I also purchased and am running Alex's e85 tune. I have not dynoed yet, but i think with e85+pulleys+tp+intake+exhaust i make about 410 or more to the wheels. Couple things i noticed are it cranks slightly longer before starting, idles a little rough because of a slightly lower idle and exhaust has little to no soot build up compared to 91 or 93 octane.
03-21-2020, 03:58 PM | #3 |
Rep 431
Great feedback. Yes i agree, with my E36 especially in the winter it takes a few attempts to crank. Not to mention a nice little smoke screen in the cold weather. I'm running just a dinan intake and ACM modded muffler hoping to hit 400 as well.
03-21-2020, 08:02 PM | #6 |
Rep 298
I drive as close to empty as i can. On my car as long as i am about 23 miles or lower until empty on 93 or 91, and switch over to e85 i have no problems. Alex also recommended to switch back to 91 or 93 after running a few tanks of e85 to prevent corrosion issues. i typically run 6 or 7 tanks of e85 then switch back to 93 for a few tanks.
03-21-2020, 09:59 PM | #8 |
Rep 431
03-21-2020, 11:46 PM | #9 |
Rep 3,988
Having an few issues with my e85 tune.
I do have becker headers so that might be some of it as I had a slight issue on 93 also but it got worse with e85 even thou Alex said he made changes for headers, it bogs/stumbles at low rpm high load. Had the car freak out and go into limp mode a few times even on fresh E85. Will get my injectors cleaned/flow tested once businesses are back to normal. Or just switch back to 93. Not sure the benefits are worth it. |
03-22-2020, 12:47 AM | #10 |
Rep 431
Hmm definitely not an expert but I did have a similar issue with a previous vehicle which tuned out to be spark plug/coil related. Hope you get it ironed out.
03-23-2020, 07:17 PM | #11 |
Rep 561
03-23-2020, 07:49 PM | #12 | |
Rep 684
03-23-2020, 08:18 PM | #13 |
Rep 431
Yes. Just reload the proper map (7-8min process).
LakeSurfer819.00 |
