11-16-2020, 03:21 PM | #1 |
Rep 485
Front Window Gasket Help
Hi all- I have searched all over this forum and the web to find answer to this question, but I have had no luck so here I am asking for your help. I have two window gaskets that I need to install (Part #51767157531 and #51767157532). My car did not have these gaskets at purchase (got a nice discount for the parts not being there) and this results in the windows violently shaking and hitting the window trim when at speed. The issue only occurs when going 80+, but still, I would like to be able to drive at those speeds without the window feeling like it will shatter.
Has anyone ever installed these parts, or if not, think of the best way to install these? I am assume there may be an adhesive used to attach the gasket to the trim, but similarly I have not seen information on this anywhere. Thank you for any input you can provide! I will add pictures later today of what the window trim looks like in its current form. |
11-16-2020, 05:32 PM | #2 |
Rep 412
I just replaced these parts recently.
Step 1: Remove the window trim, see this video for a good example. Step 2: Created a soapy water solution and put it in a spray bottle. Spray the rubber moldings and the window trim liberally. Step 3: Slide the thin edge of the molding into the window trim starting at the long end of the trim and slowly pull it towards the curved end. You may need to remove and re-lubricate the parts several times to accomplish this. Install the larger molding first and the shorter molding second to make it easier. |
11-16-2020, 05:59 PM | #3 | |
Rep 485
