      07-06-2020, 11:15 AM   #1
SonnyJack
Drives: '09 E92 M3/'18 F83 M4
For those w/enclosed trailers
My experience this weekend made we quite glad to have a trailer to transport my car to and from the track. However, I hadn't counted on an inability to drive on to/off of the trailer. Luckily my buddy had a portable winch which we were able to MacGyver so I didn't need to plead for labor at the end of a brutally hot two-day track event.
Any one have a recommendation for a good portable winch? And would it need to be rated for the weight of the car or is it not that exact?
Off topic, but my issue was minor compared to the young man who had a bad off and brutally swiped the tire barrier with his "new" Cayman GT4. Passenger side was just plain mangled. Felt bad for him.
Thanks,
SJ
AA Gen 2 Lvl 2 w/Meth; MagnaFlow catless x-pipe; Dinan Underdrive Pulley; VAC Coated Bearings; ARP Rod Bolts; Oil Diverter Valve; Dinan Strut Braces; Dinan Rear Toe Links; ECS Rear Trailing Arms; MCS 2-Way NR w/700F-1000R; GC Camber Plates; AKG 75D MM & 95A TM; CAE Shifter; Titan T-S5; StopTech ST60 380mm/ST40 355mm; MFactory DS; Zebulon Splitter; Zebulon 330 Rear Wing; Gutted w/Piper Motorsports Custom Cage; OMP WRC-R Seats
      07-06-2020, 11:24 AM   #2
dparm
Stop the hate, get a V8
dparm's Avatar
What prevented you from driving on and off the trailer?
Past: 2011.5 M3 sedan ZCP
      07-06-2020, 11:33 AM   #3
SonnyJack
6MT clutch/transmission was completely gone. Engine was running and could select gears but car did nothing but rev. I've since listened to the audio and it sounded rather fatal when it went. Have a 9am drop off tomorrow w/RRT in Virginia. Premium pricing but they do great work. We'll see what they say.
      07-06-2020, 11:44 AM   #4
OG Shark
OG Shark's Avatar
4693
Drives: Angry
Thanks,
SJ
Superwinch, Warn, Smittybuilt. Superwinch has one that is set up in a tool box that is pretty plug & play. Any winch with enough capacity can typically be made to work though depending on how you secure it to the trailer so lots of good options out there. Would recommend a synthetic rope in place of the steel cable. Personally would look for a minimum of 4k lbs but what you are needing to cover is the rolling resistance.
A mount using a trailer receiver can be fabbed up pretty easily and then be a very quick hook up if you are not wanting it to be permanently mounted.
You can also use a come along if not wanting to go all out on a winch. Not as much fun but can be a workable solution.
SonnyJack326.00
      07-06-2020, 12:39 PM   #5
SonnyJack
Much appreciated!
      07-13-2020, 10:15 PM   #6
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
I would think you could get a winch rigged to the front d-rings. As long as you're not dragging the car, that should do it.
RRT is fantastic. Julie Wolf had them set up her IP car and she then proceeded to win on tracks she’d never been to before. She’s good, but having them set things up surely helped a bit.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      07-14-2020, 05:50 AM   #7
SonnyJack
Using the D-rings is exactly how we got the car into the trailer. Thankfully my driving coach had an extra cable which we were able to run through the d-rings and pull the car into the trailer. I'm thinking of something more permanent as a setup. I've got lower cabinets so thinking I can mount something on the floor inside those cabinets.
After RRT fixed my exhaust issue from last year they corner balanced me and I was amazed at how much better the car felt after that. They'll be getting my money from now on.
      07-14-2020, 08:56 PM   #8
admranger
Retired Curmudgeon
admranger's Avatar
When all else fails use your ratchet straps to pull the car forward, chock wheels, move to next set of d-rings, rinse and repeat.
I’m sure a trailer service center could mount a winch for you. Probably wire it so you can use the car as shore power as well.
SonnyJack326.00
SYT_Shadow11482.50
