      03-29-2020, 04:10 PM   #1
Shrike360
Drives: 2009 E92 M3, 2011 Porsche CTT
Test pipes and rattling noise
Had a shop do a swappable test pipe setup (V-band) on my car over the week. Got it back, and I noticed a sort of rattling noise (or maybe a resonance) once you start it up and move it in gear. Weirdly, after getting onto the road and speeding up, the noise is gone at the next stop.
Any thoughts on what could be causing the noise? I checked the pipes, there were only two things that looked like the could cause a noise. The brackets hanging down that are typically connected to factory pipes, and a small body screw. But there didn't seem to be enough play in the pipes to make contact. And of course, there was no noise when I tried to take a video.
      03-29-2020, 04:51 PM   #2
RYDEM3
Philippines
48
Drives: ///2008 e92
Does the rattle noise happen every time it starts up and move in gear like you say? If it does why not take it back to the shop and have them check it out? Curious which vbands did you go with and what diameter did you use 2.25 or 2.5?
      03-30-2020, 10:36 AM   #3
Shrike360
It's a 2.5", they used a Vibrant 1490. Am going to drive it a bit more and see if the issue persists.
      03-30-2020, 02:50 PM   #4
//steve\\
//steve\\'s Avatar
Drives: 2012 E92 M3
Keeping an eye on this.
I've had this exact same idea from day 1 about how I'd want to do primary cat deletes for my own car.
      03-30-2020, 07:36 PM   #5
Redd
Might be exhaust resonance vibrating the drive shaft heat shield.
      03-30-2020, 11:49 PM   #6
GORDON.M3
GORDON.M3's Avatar
Drives: E92 M3 • F25 X3 M-Sport
donut gasket undersized. get an aftermarket one. thank me later.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
irokwrx765.00
      03-31-2020, 09:15 AM   #7
atopa2002
atopa2002's Avatar
Drives: Z3M, 2013 e92 M3, F15 X5
Link to the aftermarket gasket?
Thanks
      04-07-2020, 12:07 PM   #8
Shrike360
Any suggestions on a gasket?
Took it back to the shop, they didn't note anything that would make the noise. They dropped it and retightened it, now it's only making noise on the passenger side. It actually has been getting better over time, though at one point it did sound like it became open dump. Stopped at a light and it was back to normal after that.
      04-07-2020, 01:16 PM   #9
ats*ben
Drives: E90 M3
What test pipes did you end up using?
      04-07-2020, 04:27 PM   #10
Adriano917
09 M3 e93 VF650, e30 e85, Remus, Federal’s 595rs
Adriano917's Avatar
Drives: BMW M3
You still running resonators ? I had a similar issue and had them removed and never had the problem again.
09 M3 E93 - VF650, AFD e30 e85, Remus Race, Federal’s 595 rs-pro’s.
      04-09-2020, 12:57 PM   #11
Shrike360
VRSF test pipes, since the Rogues seem to be constantly out of stock.
Still running resonators, but don't know why they'd be the cause. The sound definitely seems to be coming from near the header connection.
      05-13-2020, 07:02 PM   #12
mab543
mab543's Avatar
18
Drives: E93 M3
Running the same ones, sounded great for a while and now I’m not so sure... sounds like they are loose but all seems tight. Going to get a better look this weekend.
      05-13-2020, 08:06 PM   #13
GORDON.M3
GORDON.M3's Avatar
pm me and I'll send you a part number for a tested gasket that works with most aftermarket x-pipes/testpipes.
      05-13-2020, 09:07 PM   #14
Shrike360
Ended up picking up some fresh OEM gaskets and put them on last week. The passenger side gasket seemed to be stuck to the flange on the header connection. Seems like it wasn't seating well against the test pipe. Replaced it and the noise has virtually disappeared. It popped up briefly when I started up the car after driving into a gravel parking lot. Haven't heard it again since that time.
      05-14-2020, 10:23 AM   #15
ppatel14
ppatel14's Avatar
Drives: 13' E92 AW ZCP 6MT
Subscribed, having a similar issue.
2013 E92 ZCP /// Alpine stage 2 tune, Bomiz Race X-Pipe, ARC-8 wheels, Vorshlag camber plates, Wheel studs, TMS spacers F15mm/R12.5mm, Stoptech SS lines, BW brass caliper guide
      06-14-2020, 12:37 AM   #16
Shrike360
Update. Rattling noise is fully back after a month. Will look into the aftermarket gasket
      06-14-2020, 11:52 AM   #17
R-35
Drives: 2011 E92 M3
Could you PM me the part number for that gasket. I have an undercarriage rattle I'm pretty sure it's the donut gasket. Thanks.
      06-15-2020, 09:07 AM   #18
MikeYQM
MikeYQM's Avatar
Drives: 2013 BMW M3 ZCP
I have a rattle, at about 2k RPM under moderate acceleration, often when the DCT is in a higher gear and lugging a bit. No noise otherwise. Wonder if mine is related?
2013 Fire Orange II E92 M3 ZCP
Bimmerworld (Quad) Resonated X-Pipe, AFe Stage 2 CF Intake, Carbon Project CF Plenum, Epic Motorsports Race Tune, Rogue Engineering Power Pulleys, Continental Extreme Contact Sport
      07-11-2020, 11:50 AM   #19
Eja144
Eja144's Avatar
Drives: 2008 E90 M3
Sounds exactly like what I had. Ended up being bad donut gaskets. Replaced them once and fixed the noise for about a week, then it returned. Turns out the new driver side gasket shit the bed. Knocking on wood that the new one holds up.
      07-14-2020, 06:34 PM   #20
seamax319
Drives: BMW E93 M3
can we get the part number for the aftermarket gasket.
      07-15-2020, 02:43 AM   #21
atopa2002
atopa2002's Avatar
https://www.fcpeuro.com/products/bmw...js-11627830668
      07-15-2020, 12:40 PM   #22
seamax319
Drives: BMW E93 M3
Originally Posted by atopa2002 View Post
Search this Thread:
Advanced Search
