Go Back   M3Post - BMW M3 Forum > M3 Marketplace > Private Sellers - For Sale / Trade / Wanted > Wheels and Tires Items
BPM
      05-06-2017, 01:35 AM   #1
untrakdrover
Drives: 2014 328d
BBS 19in RGR M3 Offsets
USD 3,200.00
✓ Will Ship
BBS RGRs in Diamond Black Finish. Offsets are perfect for e90 (all models) and E46 M3.
Fronts: 19x8.5. Offset +25mm - 235/35/19 Bridgestone Potenza RE750 - 340 Tread Wear Rating
Rears: 19x10 . Offset +32mm - 275/30/19 Bridgestone Potenza RE750 - 340 Tread Wear Rating
$3200 plus shipping. (circa $4300 new from tirerack.com)
      05-06-2017, 03:06 PM   #2
nachob
Drives: 2004 330i ZHP, 2022 Cayman T
I think you have the offsets backwards fellow RGR friend! The fronts are usually 19x8.5 ET 32 and rears are 19x10 ET 25.
Some notes on E90 M3 fitment.
They will fit no problem, but you will probably want to run a BBS PFS 5mm spacer in the front. This is readily available from BBS USA in Georgia since stock 8.5" wide e90 M3 wheels were et29 offset. The spacer will push them out to stock offset plus 2mm extra and look awesome!
If you want to add the 5mm spacer, I recommend you get the BBS PFS spacer as it is specifically made for this wheel and makes them truly hub-centric. It takes the place of the PFS adapter. It includes longer bolts.
They are also lighter than factory M3 wheels and pretty strong as they are forged. Not to mention they have a cool lip!
Good luck with sale.
      05-06-2017, 04:09 PM   #3
jamba
jamba's Avatar
Philippines
162
Drives: M3 E90 Jetblack
2009 BMW E90 M3  [0.00]
interested. how much tread is left on the rubber?
also, what's the condition of the other wheels since you only posted one pic.
I'm local and can look this weekend if you aren't able to take more pics
check out my YouTube feature film:
