      06-19-2019, 06:27 PM   #1
bmwpower603
Drives: E91 wagon
6MT gear box fluid
Going to change my gear box fluid. Have ista, so can do it correctly.
Real oem shows LT -3 75w-90.
Is this the fluid that BMW currently recommends?
Or should I look at the sticker on my gearbox , if there is one.
      06-19-2019, 06:42 PM   #2
ItsGary
ItsGary's Avatar
Drives: 2009 E90 M3
I don't think you need ISTA for the 6MT but check the DIY section
A complete service kit designed to make servicing your M3's transmission a little easier, features 2 liters of FFL-4 fluid which replaces the original MTF-LT-2 fluid
https://www.fcpeuro.com/products/bmw...t-e9xm3servkit
Instagram: @Namsaur
'09 335i Coupe - Alpine White/Black - SOLD
      06-19-2019, 06:46 PM   #3
ciges
ciges's Avatar
Drives: 2008 E90 M3 IB SLICKTOP 6MT
I use Redline D4 ATF,much cheaper at $12.49 per qt.You can use ISTA to run pump to get all fluid out of trans cooler.
      06-19-2019, 07:10 PM   #4
E46NYBMW
Drives: E46 M3
I use Royal purple. Ran it on my E46 and now on my E93 with no complaints
      06-19-2019, 08:04 PM   #5
Banana Hammock
Beefcake
Banana Hammock's Avatar
3340
This thread is worth a bookmark.
https://www.m3post.com/forums/showthread.php?t=1343867
Akrapovic | Alpha-N | ARC | IND | KW | Varis | Volk | Vorsteiner
@kontradictions
      06-19-2019, 10:02 PM   #6
bmwpower603
Drives: E91 wagon
Just trying to find the same fluid the car came with from factory.
Iím having clicky/ notchy feeling from 1st to second gear.
Iíll prob have to wait to do it. Since the strainer will Deff need to be ordered, along with plugs.
      06-20-2019, 12:55 PM   #7
Scharbag
Scharbag's Avatar
Drives: 2011 E92 M3
2011 BMW E92 M3  [0.00]
Yup, you really do need to run the pump for 20 to 30 seconds when draining the old fluid as there is a lot in the cooler. Also, you need to run the pump again when filling.
I also use Redline D4 ATF and it works great, nice and smooth.
Cheers,
2011 E92 M3 - 6MT, ZCP, Dinan Stuff
A wise friend told me "I stopped trying to make a slow car go fast. Instead, I bought a fast car." Sound advice.
Search this Thread:
Advanced Search
Copyright ©2000 - 2019, vBulletin Solutions Inc.
