BPM
      08-15-2017, 12:59 PM   #1
02jcrane
02jcrane's Avatar
Drives: E63 M6
ABS / DSC light on
Had my car for about 3 weeks now. Drive it fairly soft most days. But I've definitely tested out its full potential too. Whilst having a little "play" on some slidey cobbles today, nothing too punishing at all and suddenly the ABS / DSC warning lights have come on. Seems very coincidental that now a sensor has failed? Any thoughts? Hopefully overnight she'll fix herself?
Otherwise I'll get it code read next week. But in 2 days I'm due to have a small track day. She currently won't let me disabled traction control, where is the fuse kept so I can do this myself?
      08-15-2017, 01:10 PM   #2
Shiza
Shiza's Avatar
1195
Drives: M3, X5, Ram 2500, Wrangler
You were sliding around? Does your steering wheel not seem straight anymore?
      08-15-2017, 01:11 PM   #3
02jcrane
02jcrane's Avatar
Drives: E63 M6
Nope not even sliding around. Just foot to the floor in first, didn't make it to 2nd before the lights came on. Yeah had a motorway drive home, steering wheel is straight
      08-15-2017, 02:05 PM   #4
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
Steering angle sensor is notorious for setting these off.
      08-15-2017, 02:16 PM   #5
azndrunk74
Drives: Frozen Black F10 M5
try resetting the steering angle sensor. you will need software (or a shop) to do this. i use tool32, personally.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
      08-15-2017, 10:26 PM   #6
02jcrane
02jcrane's Avatar
Drives: E63 M6
Thanks all. Once I've got this fixed, I'll post back.
For now, anyone know how to disable traction control manually? I'm back to track her
      08-16-2017, 01:32 PM   #7
02jcrane
02jcrane's Avatar
Drives: E63 M6
Had the codes read 5DF0 and 5DF1. Cleared and staying off for now. I'll see how the next few days of driving go.
After a search on this forum and google, YouTube. Seems to be a fairly common BMW problem. Can be fixed. However, I really don't have time or tools. I'll try convince an Indy to repair. Doesn't need replacement it seems.
Anyone else had similar issues?
      08-28-2017, 03:43 AM   #8
02jcrane
02jcrane's Avatar
Drives: E63 M6
Update so far - problem is intermittent. Fairly annoying, but there ya go. I'll get a permanent fix if and when it becomes a permanent problem / fault
      08-11-2018, 10:18 AM   #9
RD1M3
Drives: '11 JZB E92 M3
I had the ABS and DSC lights come on, along with the following warnings on iDrive:
Driving Stability! Drive moderately
DBC malfunction! Drive carefully
Start-off assistance inactive!
Dealer pulled codes 5D91, 5D93, 5D96. Issue was a wheel speed sensor. Replaced it and solved the problem.
'11 Jerez Black DCT E92 M3 - IND | MPE | KW HAS | Forgestar F14 | Mode Carbon V1 FRP
      08-14-2018, 08:47 AM   #10
dizzyF30
dizzyF30's Avatar
135
2009 BMW M3  [0.00]
From my experience, it could be a number of things.
I had this issue a couple of months ago and unfortunately in my case, it turned out to be the DSC control unit. Carly showed code: 5DBB.
Good luck and let us know what the culprit was.
Search this Thread:
Advanced Search
