04-16-2014, 01:43 PM | #1 |
Rep 6,734
Solution for KW Clubsport Inner Wheel Clearance Issues
Problem -
KW Clubsport coil-overs reduce inner wheel/tire clearance by 12mm to 15mm relative to OEM. This inner clearance reduction is due to the stack height of the KW helper springs, main springs, and spring perch. This stack height results in the spring / perch landing at the edge of the tire. BMW's OEM design places the spring perch above the tire (resulting in more available inner clearance). This inner clearance reduction limits wheel and tire sizing and results in the need for spacers, and/or negative camber. I'm a big fan of running 275mm tires in the front which has resulted in a need for spacers on most of the wheels that I have ran to date. See the picture Below (inner clearance with 18x10 et15 and 275/35/18 BF Goodrich G-Force Rivals) I have grown tired of dealing with this issue so I contacted the professionals to discuss my options. My first call was Malek at MRF Engineering. Malek knows the M3 better than anyone I have met, and he specifically has tons of experience with KW Clubsports. Next I contacted KW themselves. Here are my findings. Solution - Raise the spring perch. There are a couple of ways to do this. Option One - eliminate the helper spring. I have never liked this solution because the helper springs are there to keep the main spring in place when the suspension is un-weighted (going over a large bump or curbing on the track). Without the helper spring it is possible that the main spring would become miss-aligned which is not a good thing. There are suspension systems without helper springs, and there are people who have successfully eliminated the helper springs on their KW suspension. I simply didn't think that route was best. Option Two - Install a shorter main spring while leaving the helper spring in place. This option also creates some potential for problems. The main problem being that the shorter main spring could bottom out (aka block out) prior to the shock/bump stop. This would result in unacceptable suspension feel / performance. Imagine hitting a hard bottom of a metal spring at the end of its travel vs. the more progressive feel of the bump stop. In order to determine the likelihood for success, I contacted KW to discuss this option. KW has not tested and does not warranty this fitment but they were nice enough to provide me with their assessment. KW believes that the installation of a 30mm shorter spring will work at or near my ride height. I will just need to make sure that the suspension will bottom out on the bump stop prior to the spring running out of travel. This change will limit my height adjustment slightly because I will be effectively reducing my maximum spring travel from 92mm to 80mm. This should be a non-issue at or near the ride height that I run. It will however, in theory, reduce my maximum ride height (and travel). In other words I won't be able to raise my ride height as high as would have been possible with the longer spring. This shouldn't be an issue for me because I don't expect to raise my car more than 1/2" from it's current height. Malek at MRF engineering will be performing the install and we will share the results. If my calculations are correct, this change will allow the fitment of 18x10 et25 wheels with 275/35/18 tires in the front without the use of spacers. Stay tuned!
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 10-08-2014 at 04:14 PM.. |
04-16-2014, 11:33 PM | #2 |
Admiral
934
Rep 3,887
Interesting. Best of luck on your swap and I'm looking forward to the result!!!
04-16-2014, 11:43 PM | #3 |
Rep 18,878
Drives: BMW
The combination of a shorter coil spring and a "no load" Swift helper spring will reposition the adjustment collar towards the top of the tire and get the clearance you need for the best of both worlds. Added bonus allows to dial in the spring rates you want.
We've done this on a number of track M3s, including our own. Go this route and you'll be fine. If you need the swifts - we're an authorized dealer.
04-16-2014, 11:56 PM | #4 |
Rep 3,633
On my AA coils that use Hyperco springs my problem is the perch itself that on an 18" wheel sits right next to the inner barrel. (A taller 19" wheel seems okay as the inner barrel is above the perch) I have about 2mm of clearance on a 18x9 et 22. et 25 would need spacers. Curiuos to hear your results as I have thought about this issue myself.
04-17-2014, 12:43 AM | #5 | |
Rep 6,734
'23 X7
04-17-2014, 12:54 AM | #6 | |
Rep 18,878
Drives: BMW
The no-load helper springs provide only enough tension to keep the springs from dislodging/rattling - without affecting spring rates.
04-17-2014, 01:16 AM | #7 | |
Rep 3,633
04-17-2014, 01:25 AM | #8 | |
Rep 18,878
Drives: BMW
Would need to know a bit more specs on your setup, including dampeners, spring brand/length, as well as wheel/tire setup. Feel free to email or call if you want to discuss in detail.
04-17-2014, 07:54 AM | #9 |
Rep 1,665
do you have any photos that i could look at
04-17-2014, 11:03 AM | #10 |
Rep 18,878
Drives: BMW
Not handy, sorry. I'll get some next time one of the cars comes in for pre-track inspection.
04-17-2014, 11:51 AM | #11 | |
Rep 6,734
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 04-17-2014 at 01:09 PM.. |
hsaguirre72.00 |
04-17-2014, 12:14 PM | #12 | |
***Major MammelToe
159
Rep 1,139
Let me know how this works. I am heading the same route as you. I have been thinking about this problem for a while.
E92 M3 SG DCT - AA Filter, Verstraβe Paddles, ECS SS, MH race stud, Stoptech BBK, MR Exhaust,RE Pulley, BPM Tune,Euro bumper and GTS lip, Euro MDM & DCT, KW CS, Recaro PP, TMS Soild Diff Mounts, MRF solid subframe mounts, GTS aero, RPM track built motor.
04-17-2014, 12:30 PM | #13 | |
Rep 18,878
Drives: BMW
If going this route - the KW perches need to be milled down a couple of millimeters to accept the new springs, which we perform in-house.
04-17-2014, 12:42 PM | #14 |
***Major MammelToe
159
Rep 1,139
Will the KW camber plates need modification?
04-17-2014, 01:01 PM | #15 | |
Rep 6,734
My understanding is that the greater the travel range of the spring the better considering I'm reducing that range. Plus I have not been dissatisfied with the stiffness of my current spring. My goal is to make this change while maintaining the same performance characteristics of my suspension.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 04-17-2014 at 01:11 PM.. |
04-17-2014, 02:23 PM | #16 |
Rep 18,878
Drives: BMW
If going with a non-KW spring, yes.
04-18-2014, 11:41 AM | #17 | |
Rep 6,734
The KW Spring inner diameter is 61mm. As Tom stated above, Swift has 60mm inner diameter springs (Eibach also has 60mm diameter springs). In order to fit the 60mm spring EAS is milling the KW spring perch. I would prefer not to have to take this step but, considering the KW spring is on back order, I'm open to it. Swift Spring Specs (there are other options but I am looking to maintain the 90nm spring rate).
As I posted above, the standard KW spring is 90nm / 170mm (92mm travel) and I was planning to drop down to KW's 90nm / 140mm spring (80mm travel). My opinion is that the 127mm Swift spring is too short because there is not enough thread available on the KW shock body. Based on my tests simulating the 140mm spring, the 152mm spring is going to be too long (140mm spring will reposition the perch barely high enough to clear the tire). I think that this is the reason that EAS has been swapping the KW helper spring for the shorter Swift helper spring... Am I right Tom? I made a call to Eibach to determine their options. Eibach happens to have a 60mm diameter, 90nm / 140mm length spring with 87mm of travel. I ended up ordering both the Eibach spring and the KW spring. The interesting thing about the Eibach option is that it is the same length as the 140mm KW spring but has 7mm of additional travel (Eibach is using thinner wire). This is great because it gets me closer to the 92mm of travel on the KW spring that I am replacing (90nm / 170mm). I'm expecting that I will need to machine the KW spring perch to fit the Eibach spring but I'm holding out some optimism that it will fit despite it's 60mm diameter vs KW's 61mm....
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 04-18-2014 at 11:50 AM.. |
04-18-2014, 12:35 PM | #18 |
Rep 3,735
No, they will not. The KW Helper spring sits at the top of the front suspension and changing the main spring will have no affect on the camber plate.
KW says their springs are 61MM springs in diameter, while Swift and Eibach ERS springs are all 60MM.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
04-18-2014, 04:46 PM | #19 |
Rep 1,665
don't they take the helper spring out?
04-18-2014, 08:51 PM | #20 |
Rep 1,805
why not just keep running the spacer? was a non issue for me running 275 and 285
17' M2 DCT - KW CS - Re71r - Carbotech
BW C13 - 1:57:2 ACS - 1:49:6 WSIR - 1:30:6 |
04-18-2014, 08:59 PM | #21 | |
Rep 3,422
Also interested in why spacer solution isn't preferable over clubsport modification for owners
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
04-18-2014, 11:56 PM | #22 | ||
Rep 6,734
Why do I want to fit these tires? Because they are one of the few tires available in 275/35/18 and 295/35/18 sizes which are the closest match to OEM diameters. In addition they are very wide, maximizing tire contact patch. If I can swap springs without any ill effects, why not?
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 04-19-2014 at 12:05 AM.. |
