07-04-2023, 09:31 AM | #1 |
Rep 309
Drives: 2008 BMW M3
CCC to CIC now looking to upgrade Combox
Upgraded 2008 m3 to CIC. Looking to upgrade combox. I have a TCU, what else is needed? Thank you in advance for your help.
07-05-2023, 05:18 PM | #2 |
Rep 452
You need the kufatec wire harness adapter. The comboox takes place of the MULF2 and the TCU. The CIC screen, head unit, screen harness, USB and harness. But sounds like you have those.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
georgebmwM3312.50 |
07-05-2023, 08:51 PM | #3 |
Rep 1,939
georgebmwM3312.50 |
07-09-2023, 06:39 AM | #4 |
Rep 309
Drives: 2008 BMW M3
07-10-2023, 11:33 AM | #5 | |
Rep 452
BMW Combox retrofit wiring harness for TCU and MULF to Exx- and Fxx-series https://www.ebay.com/itm/32487625400...Bk9SR6ritYmoYg There's no point to getting a new combox from the dealer. I'm not sure you can register the imei anymore--and it'll be difficult when BMW sees your vin as a pre-LCI anyway (I think someone did it here on the forum and it turned out being a huge PITA to get it to work). Here's "the latest" combox that is 4G with GPS: 84102447925 https://www.realoem.com/bmw/enUS/sho...diagId=84_0800 I would NOT pay anymore than $75 off of ebay as it would be a rip off: https://www.ebay.com/itm/17568583563...3ABFBM9rTTiahi
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
georgebmwM3312.50 |
07-10-2023, 06:55 PM | #6 |
Rep 1,939
All 4G combox units are deactivated as of 02/2022.
Go buy any used combox that does not look like it was under the ocean (a lot get water damaged). It is best to buy one with the connectors included with the module. If you do not get the connectors with the combox you can order them at the dealer. Get the black and green connector with the white insert and not the blue one with the black insert. I can't find the part numbers. Do not get the kufatec adapter. In my experience they connector doesn't seat properly causing issues. The pin in method of install is the superior way to install a combox. The antenna wires will need to be adapted with a cheap $7 cable: https://www.ebay.com/itm/383103945523?var=651682258708 If you have the center console USB you will need an extension cable for the combox: https://www.ebay.com/itm/264664294201 and a most bus loop (OEM one is 61136917541): https://www.ebay.com/itm/20308037098...3ABFBM8unCoqhi The install is super easy and I installed a full CIC + combox in the previous owners condo garage immediately after I bought my M3. 1. Remove the trunk floor. 2. Remove the two 10MM nuts holding the bracket to the car. 3. Disconnect all of the electrical connections. 4. Remove the TCU and MULF (if equipped) 4 8MM nuts per module. 5. Install the most terminator to the MULF most lines (if equipped). 6. Plug in the USB extension cable to the black HSD line. 7. Swap over the power, ground and three microphone wires from the TCU connector to the combox connector. 8. MULF equipped cars will need an extension harness pinned in if you want to retain aux. (None MULF cars can code aux back in) 9. Bolt the combox to the bracket with the 4 8mm nuts. 10. Plug in the main combox connector, TCU most lines, black USB extension cable, tan BT antenna with adapter. 11. Bolt the bracket back to the car. 12. Code the car for combox. |
georgebmwM3312.50 AlsoBoris3.00 |
03-13-2024, 02:33 PM | #7 |
Rep 18
I ordered everything else that you mentioned in this. I can't find the instructions on the Pin in method though. I too thought that the kufatec adapter is ridiculous. Wondering if you could please link me to that method?
03-13-2024, 09:30 PM | #8 |
Rep 452
You have to modify the kufatec connector. It's not at all a big deal.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
