Hi guys,
Macht Schnell's bushings are machined from 6061-T6 aerospace aluminum to provide a firm, solid suspension mounting point from subframe to vehicle eliminating any flexing which greatly improves feel and handling. They were created to reduce unwanted flex and as an improvement over the spongy stock bushings, and are used on M3 GTS/CRT as well as M5/M6.
A must for aggressive or track driven vehicles, Macht Schnell’s Solid Aluminum Differential Bushing kit reduces unwanted flex and as an improvement over the spongy stock carrier bushings, providing a firm, solid differential mounting point to subframe to vehicle, keeping the tires firmly planted on the ground during launching/shifting and providing maximum energy transfer to the rear wheels – where it counts.
Solid Aluminum Subframe Bushing Kit Features:
- Noticable reduction of lag under launching/shifting
- Zero subframe movement under extreme cornering
- CNC machined from 6061-T6 aerospace aluminum
- Wider footprint allows wider weight distribution/torsional rigidity
- Will not compress, crack or separate like rubber bushings
- A must for aggressive or track driven vehicles
- Chamfered edges allows easy installation
- Retains factory lip for removal
- Includes OEM fasteners for complete worry free-installation
Solid Aluminum Subframe Bushing Kit Contents:
- (4) Solid Aluminum Subframe Bushings
- (4) OEM BMW Subframe Bolts
Solid Aluminum Differential Bushing Kit Features:
- More energy transfer to rear wheels, compared to stock rubber/foam units
- Prevents broken differential bolts on aggressively driven M3/1M vehicles
- Will not compress, crack, deteriorate, or separate like rubber bushings
Solid Aluminum Differential Bushing Kit Contents:
- (3) Solid Aluminum Differential/Carrier Bushings
- (3) OEM BMW Differential/Carrier Bolts
Models Supported:
2011 E82 1M
2008-BMW E9X M3
https://www.trinityautosport.com/e9x-2008-2013/suspension-bmw-e9x/solid-aluminum-subframe-bushing-kit-e82-1m-e9x-m3
https://www.trinityautosport.com/e9x-2008-2013/engine-drivetrain-bmw-e9x/solid-aluminum-differential-bushing-kit-e82-1m-e9x-m3
Feel free to contact myself, or joe@trinityautosport for any inquiries and/or orders.
Models Supported:
2011 E82 1M
2008-BMW E9X M3
