pm me price for 10/15 mm spacers with conversion kit and red lugs to 91204
62.7KVIEWS
128REPLIES
05-24-2023LAST POST
jayjaybelbel wrotePM coming your waypm me price for 10/15 mm spacers with conversion kit and red lugs to 91204
looking for a set for my bbs lms, any suggestion?
jayjaybelbel wroteBring the car to our shop in Anaheim if you are local.looking for a set for my bbs lms, any suggestion?
Hi,
Regarding the length of your wheel studs, are they measured from the shoulders or the entire length of the stud? If it's the entire length of the stud, what is the measurement from the shoulder going into the hub?
I'm trying to get the effective length of the stud to see if I need opened ended lugs for each of my wheel applications (I'm running BBS LM-R, OEM plus 12mm & 15mm spacers, and a winter set). Hoping to get a one size fit all conversion without too much stud exposure. Ideally I would like to get closed end lug nuts without any stud exposure.
Thanks!
Thanks!
Ra_ wroteMeasurement is total stud length.Hi,
Thanks!
To safely run a 15mm spacer, you need to run a 90mm stud. 12mm can use a 75mm.
Pm me price for 12mmx1.5 macht schnell 75mm studs and 12mmx1.5 muteki sr48 in black tuner lug nuts. Shipped to 60714
Thanks
Thanks
m3whip wrotePM coming your wayPm me price for 12mmx1.5 macht schnell 75mm studs and 12mmx1.5 muteki sr48 in black tuner lug nuts. Shipped to 60714
Thanks
What is the stock dimensions?
KawBoy wroteStock meaning no spacers? if so I would run the 44mm stud. That one is the smallest and does protrude past the wheel generally.What is the stock dimensions?
Yes Kevin, no spacers. I am trying to not have studs protruding too much. Wheels are 359 if that matters.
Thank you.
Thank you.
I need 75mm studs for my fronts, and I believe I want to do 90mm in the rear. I want to ask your advice: For daily use my wheels will not have spacers, but for track days Ill be using 20mm H&R spacers in the rear. My question is will my daily driven setup look weird with a ton of stud sticking out from the wheel when no spacers are installed? Thanks in advance.
