Just used this method recently, worked like a charm!
95.9KVIEWS
81REPLIES
5APPRECIATES
06-04-2018LAST POST
Awesome! This worked like a charm. Don't be afraid to pull with force because that is what it needs... One of the most helpful posts. Thank You!
wat is the part number?
nice job! i was too scared to scratch my paint, no i pulled the front wheels off and popped the fender liner and for the passenger i had to drop down the washer fluid resv.
Awesome DIY! I just got the OEM black chrome grills/gills and following this I did all in 20 min! Your tape idea was perfect and worked like a charm. Thanks man!
Hey man thanks! You've saved my fender...
Placing a screwdriver between the gills and the fender, will damage the fender easily.
Change them in less than 5 minutes... Piece of cake with your method.
Things needed:
Tape 3M clear for boxes
Your 2 hands
THanks!
Things needed:
Your 2 hands
THanks!
Man! Awesome DIY!!! Thanks!!!
I followed your instructions and kapow....all done with both sides in under 15 minutes....then I changed the grills, also under 15 with the other DIY here.
So easy. Cal from MS Sonic said the hardest part was just pulling and the sound it makes...he was so right. The tape method makes it very easy.
Peahi wroteYes this method rocks big time. BMW should include this method as instructions with a set if Gills.Man! Awesome DIY!!! Thanks!!!
This was great! Took me less than 20 seconds for each side.
Awesome, glad it worked out for you.
Worked as advertised for me as well. Thanks for the write up!
Worked perfectly thanks
Thanks for the write up. I'm going to give this a shot
+1
Thank You!
This worked great, you might have to use more force then you think though
Thanks for this. I just used both of your DIY's to do the side gills and grills.
Grills (which I did on my e92 335i) are still a bit of a pain in the ass, but the gills were pretty painless with this method.
An earlier reply in this thread said that Side Gill removal on the E90 is harder than the E92/93. Will the "tape" technique work on the E90? Has anyone tried it successfully?
Zeus69 wroteJust to add, I successfully used this tape method to remove and replace my side gills on my E90. As some have stated, tape it, use one hand to pinch the gills as best as you can while you grab the tape and give it a pretty good solid tug (I know, I know). Reference your new gills for tab placement and reference points for squeezing.An earlier reply in this thread said that Side Gill removal on the E90 is harder than the E92/93. Will the "tape" technique work on the E90? Has anyone tried it successfully?
After struggling for a bit to figure out how to get the gills off I came across this post -- it worked perfect! Thank you SOOOOO much for the DIY and videos. Exactly what I needed.
-Scott
-Scott
scm6079 wrote+1After struggling for a bit to figure out how to get the gills off I came across this post -- it worked perfect! Thank you SOOOOO much for the DIY and videos. Exactly what I needed.
-Scott
...and yet another "thank you" for the detailed instructions. This made the install a breeze...
