Hey everyone.
Listing up my trailer for sale. I just don't see myself using it as much. It's currently parked inside my property.
I've taken this from LA to Button Willow for 6 track days. The cabinets are insanely useful for keeping my tools in, and the countertop makes it nice to have quick access to everything during track days. Plus, with this, you don't need to rent a garage at the track!
Includes a custom installed cabinet with metal counter top ($4k to install) as well as the features below
1. Upgrade, Sloped & Extended V-Nose (Standard is 18” v-nose.)
2. Upgrade, Drivers Escape Door
3. Upgrade, Painted / Treated Floor
4. Upgrade, Security Barlock added to the Standard Flushlock Side Door
5. Upgrade, 40' Aftermarket Gray E-Track ( (4) 10' sections screwed in.)
6. Upgrade, Spare 15” Rim / Tire
7. Upgrade, Spare Inside Wall Mount ( Curbside front & high. In front of passenger side door.)
8. Standard, Rear Ramp with Dual Spring Assist, 12” Flap & BeaverTail
9. Standard, 36”w Flushlock Side Door
10. Standard, SteelTube Sidewall Framing
11. Standard, 16”o.c. Steel Tube Roof Framing with 24”o.c. Floor & Walls
12. Standard, Triple Tube Tongue
13. Standard, (4) Recessed D-Rings
14. Standard, LED Brake & Marker Lights
15. Standard, 15” Gray, Black or White Steel Mod Rims with Radial Tires
16. Standard, 3/8” Drymax Plywood Walls & 3/4” Drymax Plywood Floor (Main Floor and Ramp.)
17. Standard, 3500lb Rated Spring Axles w/ EZ Lube Hubs (7000lb gvwr & about 3700 lb payload cap.)
18. Standard, 4 Wheel Electric Trailer Brakes.
19. Standard, (2) 12v LED 5” Dome Lights
20. Standard, (2) Sidewall Air Vents
21. Standard, 18” V-Nose with Semi-Flat Roof
22. Standard, .030 Thick Aluminum Exterior Panels (Screwed. (Silver)
23. Standard, 2-5/16” Coupler with Dual Safety Chains & 7-Way Plug
