Hey all, drained my coolant on my 2008 M3 via radiator reservoir, reinstalled that screw, and refilled with my 50/50 mix of bmw genuine coolant and distilled water. Bled system via the expansion tank bleed screw 3-4 times before topping off to max line.
I was only able to drain about 1gal/4qts initially via the reservoir screw, thus being able to only fill the same 1gal/4qts of my new 50/50 mix. Apparently S65s should have around 2.5-3gal/10-12qts of coolant capacity.
Is it normal i was only able to drain out and thus fill a third of that capacity?
TIA
TIA
