For those interested in replacing parts on their M3 with the exact original equipment (OE) parts, less the BMW stamp and with no sacrifice in quality, here is the list I was able to put together from various posts, with help from other forum members and personal experience. Plus a huge additional list from member Flipmeraz (Thanks!):
Key:
L = Left or Driver's Side
R = Right or Passenger's Side
Engine
1 BMW E9X M3 ignition coils = No longer appear to be available with the same quality as OE from the OE manufacturer
3 BMW E9X M3 spark plugs = NGK (4471) LKR8AP
1 BMW E9X M3 head gasket = Elring 11127841560 or Elring 198624
13 BMW E9X M3 timing cover gasket = Elring 11127838162 or Elring 354.811
5 BMW E9X M3 oil pan gasket = Elringklinger 11137841085 or Elring 354.721
3 BMW E9X M3 oil filter kit (with seals and copper crush washers) = Mahle OX254D3 (also packaged and sold as Hastings LF667)
4 BMW E9X M3 oil pressure sensor = Hella 006097001
1 BMW E9X M3 alternator = Valeo 439675
1 Production date before 4/29/08 BMW E9X M3 AC/power steering serpentine belt = Continental 6K1065
1 Production date on or after 4/29/08 BMW E9X M3 AC/power steering serpentine belt = Continental 6DK1100
2 BMW E9X M3 A/C Belt Tensioner Pulley Only = INA 5320557100
3 BMW E9X M3 A/C Belt Tensioner Strut Only 4/29/2008+ = INA F-239109.01
6 Built before 4/29/08 BMW E9X M3 deflection pulley (aka idler pulley) = INA 5320418100
6 Built on or after 4/29/08 BMW E9X M3 deflection pulley (aka idler pulley) = Only available from BMW 11287841531
1 BMW E9X M3 alternator/water pump serpentine belt = Continental 6K1460
2 BMW E9X M3 Alternator Belt Tensioner Pulley Only = INA 5320342100
3 BMW E9X M3 Alternator Belt Tensioner Strut Only = INA F-239110.04
2 2008-2009 BMW E9X M3 air filter = Mahle (or Clevite) LX1667
2 2010-2013 BMW E9X M3 air filter = Mahle (or Clevite) LX1590
1 BMW E9X M3 throttle actuators = Siemens VDO A2C59506263 (Also sold as 13627838085M82)
3 BMW E9X M3 engine mounts = Corteco 11812283798
2 BMW E9X M3 oil cooler line (from engine in to cooler) = Cohline 17222284077
3 BMW E9X M3 oil cooler line (from cooler to engine) = Cohline 17222284078
1 Fuel Tank Breather Valve = Bosch 13907838281
20 BMW E9X M3 low pressure fuel sensor = Bosch 0261230348
2 BMW E9X M3 DMTL pump (aka leak diagnosis pump) = Bosch 0261222018
4 BMW E9X M3 fuel injector = Bosch 0280158164
Cooling
BMW E9X M3 engine coolant/antifreeze = Rowe 21066-408-03
6 BMW E9X M3 cooling pipe o-rings (x4 needed) = Victor Reinz 11531406249
12 BMW E9X M3 thermostat = Behr 11537836155
16 BMW E9X M3 Coolant Temperature Sensor - *Sold in generic boxes and labeled "O.E.M." brand from most of the large online parts retailers. The following branded sensors are not exact equivalents: FAE/Febi/MTC/Rein/VEMO.
1 BMW E9X M3 Radiator - exact equivalent not available
2 BMW E9X M3 Coolant Reservoir Cap = Rein 17117639021
Exhaust/Emissions
3 BMW E9X M3 exhaust manifold gasket for cylinders 1,6,7 and 8 = Elring 728600
4 BMW E9X M3 exhaust manifold gasket for cylinders 2,3,4 and 5 = Elring 728610
5 BMW E9X M3 Secondary Air Injection Control Valve (aka EGR Valve) for cylinders 2,3,4 and 5 = Pierburg 11727838028
6 BMW E9X M3 Secondary Air Injection Control Valve (aka EGR Valve) for cylinders 1,6,7 and 8 = Pierburg 11727838029
1 BMW E9X M3 pre-cat oxygen (O2) sensor = Bosch 17039
3 BMW E9X M3 post-cat oxygen (O2) sensor = Bosch 16793 (limited availability - now superceded by Bosch 16421)
DCT Transmission
BMW E9X M3 DCT Fluid = Pentosin 1080107
1 BMW E9X M3 DCT transmission pan = Getrag SP02228
6 BMW E9X M3 DCT suction filter = Getrag 28107842828
8 BMW E9X M3 DCT transmission filter (filter only) = Getrag 28107842840
Manual Transmission
BMW E9X M3 Manual Transmission Fluid (BMW MTF-LT-2) = Pentosin MTF2 75W-80 (no longer in production)
1 BMW E9X M3 clutch kit = LUK 03-102 (also sold as LUK 6223308000 and LUK 622330800)
2 BMW E9X M3 release bearing = INA F-232336.15 (also sold as LUK MC0800 and F.A.G. MC0800)
3 BMW E9X M3 manual transmission input shaft seal = Corteco 01033870B
7 BMW E9X M3 manual transmission output shaft seal = Corteco 01033866B
(compare to BMW 23127501712)
Other Driveline Components
1 BMW E9X M3 flywheel- LUK DMF148
2 BMW E9X M3 pilot bearing= NTN 11211720310
11 BMW E9X M3 differential output shaft seal with lock ring = No Exact Match Available - A very close match made by the same company, but at a different factory is Victor Reinz 33107510289
1 BMW E9X M3 centering sleeve (aka driveshaft end bushing) = Corteco 80000024
2 BMW E9X M3 flex disc (aka guibo) = SGF GAB01-024 (also now packaged as FEBI 32986 - send back the FEBI part if it does not have a "SGF" stamp directly on the part, older FEBI packages of this product were from a different supplier)
2 BMW E9X M3 rear right or left, wheel bearing (45 X 85 X 41 mm, with magnetic ring) = F.A.G. 805560A
Lighting
1 BMW E9X M3 Bi-Xenon Adaptive Curve Headlight Left (driver's side) Headlight Assembly (Plastic Housing) - Automotive Lighting 63117182517 *Note: These headlights do not have text painted on the chrome surround of the headlight bulb.
1 BMW E9X M3 Bi-Xenon Adaptive Curve Headlight Right (passenger's side) Headlight Assembly (Plastic Housing) - Automotive Lighting 63117182518 *Note: These headlights do not have text painted on the chrome surround of the headlight bulb.
1 BMW E9X M3 xenon control unit (Ballast) = Automotive Lighting LRB160 (also packaged and sold as Magneti Marelli LRB160)
2 BMW E9X M3 xenon bulbs = Sylvania D1S
9 BMW E9X M3 Turn Signal Bulb with Base - Sylvania - Phillips PSY24WSV
1 BMW E9X M3 Headlight Level Sensor (front and rear are the same part) = 37146853753 *Sold in generic boxes and labeled "O.E.M." brand from most of the large online parts retailers.
4 BMW E9X M3 Headlight Washer Pump = VDO 246086001007Z
Suspension - Front
14 BMW E9X M3 front tension strut right side (aka upper control arm or thrust arm) = TRW brand JTC1423
14 BMW E9X M3 front tension strut left side (aka upper control arm or thrust arm) = TRW brand JTC1424
15 BMW E9X M3 front tension strut bushing only, right and left are identical (this requires a shop press or special bushing tool for install) = Lemforder 31102283579
19 BMW E9X M3 front lower right control arm (aka wishbone) = TRW brand JTC1427
19 BMW E9X M3 front lower left control arm (aka wishbone) = TRW brand JTC1426
BMW E9X M3 front springs (non-ZCP) - Suplex 06373
5 BMW E9X M3 front wheel bearing = F.A.G. 805583A
7 BMW E9X M3 front ABS speed sensor aka dsc pulse generator = ATE 360352 or 24.0711-6209.3 or 34527853586 (1 right side and 1 left side, same part #)
6 BMW E9X M3 Front Sway Bar End Links (aka swing support bars) = Not Available (Note: TRW JTS1658 and TRW JTS1657 are not Exact OE as many other TRW suspension components are, these are lower quality aftermarket pieces)
Suspension - Rear
2 BMW E9X M3 rear trailing arm bushing = Lemforder 3058201 or 33326763092
3 BMW E9X M3 rear ball joint for wheel carrier right or left = Lemforder 3642601 or 33326792553
13 BMW E9X M3 rear lower rearward control arm with bushings right and left (aka track struts) = TRW JTC1432 or 33322283549
17 BMW E9X M3 rear left, upper rearward control arm with bushings = TRW JTC1428 or 33322283545
17 BMW E9X M3 rear right, upper rearward control arm with bushings = TRW JTC1429 or 33322283546
18 BMW E9X M3 rear left, upper forward control arm with bushings = TRW JTC1430 or 33322283547
18 BMW E9X M3 rear right, upper forward control arm with bushings = TRW JTC1431 or 33322283548
19 BMW E9X M3 rear right or left, ABS Wheel Speed Sensor = ATE 360118 or 24.0711-5191.3 or 34526870077
6 BMW E9X M3 rear upper shock mount (lower section) right and left = Lemforder 33506771738
7 BMW E9X M3 rear upper shock mount (upper section) right and left = No Exact Match Available - A very close match by the same manufacturer that is constructed of one foam piece vs OEM 2 piece foam = Lemforder 33506771737
BMW E9X M3 rear springs (non-ZCP) - Suplex 06342
6 BMW E9X M3 rear sway bar end link (right and left side) = Lemforder 33556764428
2 BMW E9X M3 rear Forward subframe bushings - Lemforder 3779801 or 33312283382
3 BMW E9X M3 rear Rearward subframe bushings - Lemforder 3779701 or 33312283383
Steering
BMW E9X M3 power steering fluid = Pentosin CHF 11S
1 BMW E9X M3 Power Steering Reservoir - ZF Lenksysteme or ZF 32416851218 *Note: Does not have green ring painted on reservoir cap.
1 BMW E9X M3 power steering pump = ZF Lenksysteme or ZF 32412283002
6/25 BMW E9X M3 one time use (crimp style) hose clamps = Oetiker, model number varies by size
21 BMW E9X M3 power steering cooler = Modine 17117522119
BMW E9X M3 multi-use, spring style hose clamps = Mubea, part number varies by which of the clamp sizes
4 BMW E9X M3 front full tie rod assembly right = Lemforder 3190401
4 BMW E9X M3 front full tie rod assembly left = Lemforder 3190301
5 BMW E9X M3 front tie rod end only right = Lemforder 32106767782
5 BMW E9X M3 front tie rod end only left = Lemforder 32106767781
Brakes
BMW E9X M3 brake fluid = Pentosin DOT 4LV (1224116)
4 BMW E9X M3 caliper guide bushings = ATE 260098 or ATE 34116758707
5 BMW E9X M3 caliper guide pin cover - ATE 990052 or ATE 34111154979
6 BMW E9X M3 upper brake caliper pins = BMW only, OEM equivalent not available
7 BMW E9X M3 front lower brake caliper pins = ATE 250153 or ATE 34116757036
8 BMW E9X M3 anti-rattle clip for front caliper - ATE 390447 *Note: These are unpainted steel so they have a silver colored appearance vs BMW black painted OEM.
12 BMW E9X M3 front pads- Textar 2331207
13 BMW E9X M3 left front pad sensor- BOWA A059091
13 BMW E9X M3 right front pad sensor- BOWA A059092
*Not Pictured - BMW E9X M3 Performance Front Brake Pads (NOTE: THESE ARE TRACK PADS, NOT THE OEM PADS THE CAR WAS DELIVERED WITH) = Pagid 8053RS19
1 BMW E9X M3 front left rotors - VNE 34212283801
1 BMW E9X M3 front right rotor - VNE 34212283802
6 BMW E9X M3 brake caliper pins (set of 4) = FTE K10005
8 BMW E9X M3 rear caliper guide bushings = ATE 260009 or ATE 34216869617
9 BMW E9X M3 anti-rattle clip for rear caliper = ATE 390445 *Note: These are unpainted steel so they have a silver colored appearance vs BMW black painted OEM.
11 BMW E9X M3 rear pads- Textar 2373001
12 BMW E9X M3 rear pad sensor (only 1 needed on rear passenger's side, no sensor on rear driver's side) - BOWA A059080
*Not Pictured - BMW E9X M3 Performance Rear Brake Pads (NOTE: THESE ARE TRACK PADS, NOT THE OEM PADS THE CAR WAS DELIVERED WITH) = Pagid 8021RS19
1 BMW E9X M3 rear left rotors - VNE 34212283803
1 BMW E9X M3 rear right rotor - VNE 34212283804
5 BMW E9X M3 front brake lines (hoses) = ATE 83.7751-0502.3
7 BMW E9X M3 center (mid car) brake lines (hoses) = ATE 83.7850-0180.3
11 BMW E9X M3 rear brake lines (hoses) = ATE 83.7752-0236.3
8 BMW E9x M3 brake vacuum pump = Hella 8TG 009 383-101
Climate
1 BMW E9X M3 A/C Compressor = Denso 471-1559
5 BMW E9X M3 A/C Pressure Sensor = ACM 0155.1023 (also packaged and sold by large online parts stores as generic "O.E.M." brand)
1 BMW E9X M3 HVAC Blower Motor = ACM 0157.0052 (also packaged and sold as Valeo 64119227670)
2 BMW E9X M3 Blower Motor Resistor = ACM 0155.1027 (also packaged and sold as Valeo 64119265892)
1 BMW E9X M3 A/C Expansion Valve = ACM 0151.0025 (also packaged and sold as Egelhof 01510025)
1 BMW E9X M3 A/C Condensor = Behr 351302611
2 BMW E9X M3 A/C Condensor Dryer Insert ($61) - Vemo V20-06-0073
Miscellaneous
1 BMW E9X M3 cabin filters = Corteco MicronAir CC1377 (80001029)
5 BMW E9X M3 hood struts (interchangeable right or left) = Stabilus 016717 (Also sold or listed as ST016717 or 4B-016717 or UPC# 194879005508) - *Note: While Stabilus 9669ZC (Also sold or listed as ST017917 or 4B-017917 or STB-9669ZC or SG402058 or UPC # 708609328968) will fit, it is not an exact match as it outputs 330NM of force vs 200NM of force for the original strut, it is not intended for the lightweight M3 hood, it is for the normal 3 series. This part is incorrectly cross referenced on some websites.
7 BMW E90 Sedan M3 ONLY - trunk struts = Stabilus SG302063
7 BMWE92 Coupe M3 ONLY - trunk struts = Stabilus SG302066
1 BMW E9X Boot lid/tailgate pushbutton (aka trunk handle) = MOCW 51247118158
5 2008-2010 BMW E9X M3 TPMS = Huff RDE008
5 2011-2013 BMW E9X M3 TPMS = Huff RDE012
7 BMW E9X M3 TPMS valve stem caps (silver or black) = ALLIGATOR Ventilfabrik, part number varies by quantity ordered
Fluids: Can't definitively prove these, but could possibly be an exact match to the OE version:
BMW 75w-140 Limited Slip GL-5 standard differential fluid, aka SAF-XJ (2007-2016) = Rowe Hightec Hypoid EP SAE 75W-140 S-LS (same style small cone caps for both BMW branded and Rowe branded)
BMW 75w-140 Limited Slip GL-5 differential fluid with extra friction modifier, aka SAF-XJ+FM (2007-2016) = Castrol Syntrax SAF-XJ 75w-140 (exact same design for the cap on both of these bottles, green cap for the BMW branded oil and red cap for the Castrol branded oil)
BMW 75w-140 Limited Slip GL-5 rated differential fluid with extra friction modifier, aka SAF-XJ+FM (red cap bottle 2016+) = Shell Spirax S6 AXME 75w-140
BMW M TwinPower Turbo 10W-60 oil = Shell Helix Ultra Racing 10W-60
BMW E9X M3 Brake Fluid = Pentosin DOT 4LV (1224116)
BMW E9X M3 washer fluid = Rowe Hightec 21104001003
Lubricants and Threadlockers:
BMW E9X M3 driveshaft CV joint grease Optitemp HT LF1 = Castrol Molub-Alloy 370-2
BMW E9X M3 flexible disc centring and centring pin of the gearbox output flange grease Optimol Olistamoly 2 L584LO = Castrol Olistamoly 2
BMW E9X Anaerob Drei Bond 1385 threadlocker for differential pinion nut = Permatex High Temperature Threadlocker Red 27200
BMW E9X M3 grease for drive axle splines Unirex S2 Grease = Exxon/Esso/Mobil Unirex S2
BMW Branded Specialty Tools:
BMW 21mm strut removal tool part # 83300491931 = Hazet 2593-21
BMW strut sleeve spreader part # 83300491930 = OEM Only - Not Available in Equivalent Form (This part is custom machined for BMW from a 23mm Stahwille 509/2 1/2" drive extension bar - a very nice piece!)
BMW Smart Battery Charger (61432358315) = CTEK 56-864
BMW Torque Angle Tool#00 9 120 sold as BMW Part# 83300490504 - Hazet 6690
Exact Equivalents Not Available:
BMW E9X M3 deflection pulley (aka idler pulley) Built on or after 4/29/08 - not available
BMW E9X M3 Wiper Blades - not available
BMW E9X M3 Adaptive Headlight Control Unit - not available
BMW E9X M3 A/C Belt Tensioner up to 4/29/2008 - not available
BMW E9X M3 Radiator - not available
BMW E9X M3 Water Pump - not available
BMW E9X M3 Water Pump Pulley - not available
BMW E9X M3 Front Strut Assemblies - not available
BMW E9X M3 Rear Shocks - not available
BMW E9X M3 Engine Oil Level Sensor - not available
BMW E9X M3 ZCP front springs - not available (non-ZCP version is available)
BMW E9X M3 ZCP rear springs - not available (non-ZCP version is available)
BMW E9X M3 oil cooler - not available
BMW E9x M3 18", 19" and 19" ZCP wheels - not available
BMW E9X M3 front, lower brake caliper pins = BMW only, OE equivalent not available
BMW E9X M3 exhaust hangers - not available
BMW E9X M3 exhaust gaskets (headers to x-pipe) - not available
Looking for exact equivalent to the OE components for any of the following:
differential pinion seal?
radiator hoses -are these Rein brand?
interior and exterior bellows repair kit (aka cv boot repair kits)?
wheel bolts?
rear axle nut? (It's not Febi brand)
front strut bearings, are these even available in OE form for purchase?
Special thanks to the following members for additional items and corrections:
Flipmeraz - huge contribution!
JsL
geoffreyaugusto
M3MPH1S
doogee
FLAMES
Drv4fun
seevin
Hoosier_M3
Mvy
Deansbimmer
ItsGary
Davisca455
Ant Man
BayAreaE93
LKN624
BenFenner
Key:
Engine
Cooling
Exhaust/Emissions
DCT Transmission
Manual Transmission
Lighting
Suspension - Front
Suspension - Rear
Steering
Brakes
Climate
Miscellaneous
wheel bolts?
JsL
geoffreyaugusto
M3MPH1S
doogee
FLAMES
Drv4fun
seevin
Hoosier_M3
Mvy
Deansbimmer
ItsGary
Davisca455
Ant Man
BayAreaE93
LKN624
BenFenner
