54.1KVIEWS
72REPLIES
44APPRECIATES
05-28-2026LAST POST
So, started the job and ran into a few problems along the way.
Nothing too big but forgot to untighten the bolts for the PS wheel before removing the belts, rookie mistake. Also dropped the bolt for the bracket for the PS pump. Gasket looked okay but guess it could've been better.
What I noticed though; it was a little wet around the sensor and if that was leaking it would drip down around the housing and it would look the same as if the gasket was leaking.
Also; rubber for the plug to the vanos solenoid was damaged, can't find a partnumber anywhere.
Last pics after cleaning, should be good?
Thread referenced by Theodore2 in Oil change mess at filter. 09-24-2023
Thread referenced by DrFerry in Sporadic oil leak 12-18-2023
And some photos of the STEELMAN PRO 78936 inserted into the female torx screw head to show how much clearance you have to work with:
Thread referenced by DrFerry in Oil Leak - e92 m3 03-23-2026
Thread referenced by DrFerry in Need Help - Oil leak 03-23-2026
I just did this over the weekend. I’m a novice so this took me a very long time to do. The various DIYs are helpful but some additional thoughts:
1. Be organized with bolts! So many parts get removed!
2. I wish I just drained the coolant. I pumped out the entire expansion tank but every hose dumps 16oz or more. I ended up with about a gallon collected all said and done. It makes a huge mess, gets everywhere, including the reinforcement plate and spills out the front hole. Have lots of catchers!
3. The A/C tensioner and deflector pulley must come off. I couldn’t find accurate torque values on the tensioner bolts. I backed one out and retightened to about the same wrench angle and got 26 Nm so that’s what I did. For the idler bolt, I just did 40 Nm instead of messing with the angle (15 Nm + 70deg). Seemed about the same; I hope.
4. Moving the power steering pump is tricky and it’s in the way making some of the oil filter bolts blind. Be patient and it bends forward pretty far.
5. For reattaching bolts, I put them on a magnet wand to line them up after I dropped one and had to take the reinforcement plate off to get it! Worked out though because there was a pool of coolant to clean up also…
6. You can tell your gasket is bad if you have oil everywhere. Another clue was some of the bolts to the OFH came out with oil on them.
7. To remove the caked on gasket on the OFH, I found rubbing alcohol worked better than brake cleaner/acetone. I also used a toothpick to avoid marring the gasket area.
I replaced the hard oil line o-rings and water pump o-ring. I found mixed information about replacing bolts. All the bolts are steel according to my magnet, so I reused them as their threads also looked fine and consistent top to tip.
Good luck to anyone going through this! It gave me confidence for more projects but quite the investment of time!
Great advice here.
I went ahead and drained the coolant from the drain port on the lower, driver's side of the radiator. I also pulled the water pump completely out and replaced it. It's easy to do when you are in there and gives you some more space. Get ready for a waterfall when you pull off the water pump despite draining the radiator.
Idk if it was said in the DIY - get yourself another oil filter. Pop the oil filter cartridge up and let the oil drain back into the engine naturally. This will save you some oil clean-up. Then install the new oil filter and o-rings when you are done.
The oil filter housing gasket kit from FCP comes with new bolts and a new pressure or temp sensor (I don't remember which one it is off the top of my head).
Overall, the work required getting to the housing gasket is worse than changing the gasket LOL
My FCP Kit came with one extra bolt. Why would they do that to me?!? It even shows the extra bolt on the website (and they charged me for it)
Spent half an hour trying to see where that other bolt goes. BTW there's 9 bolts not 10.
Torque specs :
