      03-26-2011, 01:26 AM   #1
advans
Advansolosis
39
Drives: ///M+////AMG
Weird sound from Passenger side rear wheel
Hey Guys.... Ive been noticing this weird sound coming from the passenger side rear wheel. kinda sounds a bit like a low pitch rubbing ish noise. only happens when I make a right turn and if its uneven pavement. any clue??
2011///M3_ZCP:
2009_550i_MSport_daily_driver
      03-26-2011, 03:33 AM   #2
The Woo
Drives: M3 2011
you must have just done your 1200 tune up. you dealer needs to use a differ differential oil to solve this issue. ask them to look it up, is in their log.
      03-26-2011, 08:16 AM   #3
advans
Advansolosis
39
ahh got it. I got 8000 miles on the car already, noticed this maybe 2 months ago once, but it was never a "always thing" until i swapped back into my summer wheels and noticed it more.
2011///M3_ZCP:
      03-26-2011, 10:33 AM   #4
kscarrol
kscarrol's Avatar
Drives: 2011 E90 M3
Yes, sounds like the differential issue. Just had my diff oil replaced with the new version per the SIB out on the subject. Sound is gone...
2011 Space Grey E90 M3, DCT, Comp. Pkg.
1997 Z3 2.8, Artic Silver, Tanin Red interior, MT
1974 2002tii, Inka, 5 sp manual
BMWCCA # 327475
      03-26-2011, 12:46 PM   #5
Skippy989
Drives: M3 Coupe 6MT E92
I noticed it once and only once on my 2008. Circling a parking lot making tight slow right turns I could hear a rubbing sound. I thought it was something caught in the wheel arch at first. Once the car warmed up it went away and I have yet to hear it since even after trying to replicate it. My dealer will change the diff oil but I may just leave it alone.
      03-28-2011, 01:43 AM   #6
JtBlk M3
JtBlk M3
Drives: BMW E92 M3 DCT
let me know if it gets resolved. i have been having tis problem too and i thought the tires were rubbing on the wheel arch or something because it completely sounded like rubbing. hear only on tight right turns. i didnt know others had this problem too,
please tell me what to do to fix it.
      03-28-2011, 05:38 AM   #7
kscarrol
kscarrol's Avatar
Drives: 2011 E90 M3
Do a search on differential grinding... Had mine resolved under the SIB. Take it your dealer and describe the "grinding" or rubbing noise during slow right turns and they should change the diff oil. Did the trick for me.
BMWCCA # 327475
      03-28-2011, 11:09 AM   #8
1sikbmr
1sikbmr's Avatar
107
Drives: E90 M3 6MT
This Service Information bulletin supersedes SI B33 01 02 dated March 2008.
SUBJECT
Grinding Noise from the Differential during Slow Cornering
MODEL
E90, E92 and E93 M3 from start of production
SITUATION
A grinding noise may be heard coming from the differential during slow cornering. This noise is best heard during tight cornering situations; for example, while parallel parking, driving in a tight circle, etc.
CAUSE
When the rear wheel speed differential varies during tight cornering, a slip stick effect is created on the lining and steel discs incorporated in the differential locking clutch, causing the grinding noise. This noise typically goes away as the locking clutch discs in the differential are broken in.
The break-in time varies depending on driving habits; for example, tighter cornering (working the locking clutch) means that it takes less time to break in the locking clutch discs.
CORRECTION
If a customer complaint is verified as described above on the E46 M3; E60 M5; E63 and E64 M6; or on the E90, E92 and E93 M3 vehicles, the differential oil should be replaced with a specially formulated differential oil, BMW part number 83 22 2 282 583.
PROCEDURE
1. Drain the differential oil. Refer to the appropriate model repair instruction in TIS:
Main Group 33 / Subgroup 10 / RA 0011259.
2. Refill the differential with special differential oil as shown in the illustration below.
Differential fill capacity = 1.2 liters (1.3 quarts).
3. Road test the vehicle.
With the vehicle at operating temperature, drive in tight circles (20 circles in each direction), allowing the special oil to coat the locking clutch discs.
The grinding noise will decrease when the locking clutch discs are sufficiently coated. Some slight noises may still be heard after driving in tight circles. Advise the customer that it will be necessary to drive the vehicle up to 600 miles before all noises are eliminated.
Note: Vehicles that have had the differential oil converted to this special oil should continue to use this oil whenever a service requiring the differential oil replacement is indicated.
E90 ///M3 6MT Atlantis Blue - Fox red #TEAMMODE
ESS VT1-550|Volk TE37|Recaro|STOPTECH|Ohlins R/T|Mode Carbon GT4 Lip|Umnitza V4 |Agency Power/Sosi/ACM Test Pipes|BMW PSW V1|
      03-28-2011, 11:54 AM   #9
M3LISSA
M3LISSA's Avatar
Drives: 2011 E90, M3
omg me too!!! hhow embarrassing!!! i hate it, i have an appointment with the stealership thursday
2011 E90 M3 // Alpine White // ESS // RPI // 20" BBS LM's, blah blah
      03-28-2011, 10:58 PM   #10
advans
Advansolosis
39
my scheduled appointment is April 27
2011///M3_ZCP:
      03-28-2011, 11:41 PM   #11
Gkap
BMF Movement
Gkap's Avatar
Drives: Women Crazy
keep us posted.
      03-29-2011, 11:30 AM   #12
M3LISSA
M3LISSA's Avatar
Oh that sucks. Damm such a long wait. I go this thursday, so hopefully its a simple ofluid change and i can have my car back the same day. Ill keep you posted.im bringing the service bulliten,i already printed it out.
      03-29-2011, 11:44 AM   #13
I Wanna go Fast!
Drives: 08 l E90 l AW l PREMIUM l TECH
///M 08 l E90 l AW l 6MT l TECH l PREMIUM l 19 220M
      04-02-2011, 10:56 AM   #14
M3LISSA
M3LISSA's Avatar
hey, I had my fluid changed on Thursday.. It seems for the most part the sound is gone. I thought I heard it ever so slightly on making a right slow turn yesterday. But im assuming it needs time for the fluid to work its way through thoroughly. So far im pleased with it. It was rather annoying and embarrassing too. I brought the service bulletin in and gave it to my service advisor. He told me I was "right on the money" ...lol.. shame I have to do the job for them, they should know this already, lol..
      04-02-2011, 11:02 AM   #15
geneatals
Ninja
geneatals's Avatar
Philippines
282
Drives: 2016 F80 M3
so this wasn't resolved when they did your M service initially? don't they swap the diff fluid at the M service?
2016 F80 M3 AW | Cloth/Leather: Carbonstructure Anthracite/Black Seats | CF trim | M-DCT |Adaptive M suspension | 19" Silver 437M wheels | CF Roof | Pics/Mods
Sold: 2011.5 E90 M3 AW l Black Novillo Leather | Carbon Fiber Leather Trim | ZCP | ZP2 | M-DCT | Navigation | Moonroof | 6FL l Pics/Mods
Retired: 2008 535i l AW l Black Dakota Leather l Bamboo Anthracite l ZPP l ZSP l 6FL
      04-02-2011, 11:49 AM   #16
kscarrol
kscarrol's Avatar
Drives: 2011 E90 M3
Nope. In fact it didn't start until the M service!
BMWCCA # 327475
      04-02-2011, 11:50 AM   #17
kscarrol
kscarrol's Avatar
Drives: 2011 E90 M3
It does take some time to fully resolve. The SB even says it can take 600-800 miles to completely going away. Mine did not take that long but it is gone...
BMWCCA # 327475
      04-02-2011, 10:18 PM   #18
M3LISSA
M3LISSA's Avatar
Ken, I think thats when mine started too.
      04-02-2011, 10:19 PM   #19
geneatals
Ninja
geneatals's Avatar
Philippines
282
Drives: 2016 F80 M3
m service on tuesday, one more thing to be neurotic over...lol
      04-04-2011, 08:52 AM   #20
M3LISSA
M3LISSA's Avatar
your already neurotic sweetie. It cant get any worse.. Do they have a manual for that??
      04-04-2011, 01:00 PM   #21
rebattery
batteryman
Drives: 2013 335xi msport
have the same issue @ 36000k, getting updated dif. lube---hoping it resolves the problem!!
      04-04-2011, 01:47 PM   #22
zhangzeyuandss
zhangzeyuandss's Avatar
Drives: 2011 e92 MW m3; 2014 Boxster S
Send a message via AIM to zhangzeyuandss Send a message via MSN to zhangzeyuandss Send a message via Yahoo to zhangzeyuandss Send a message via Skype™ to zhangzeyuandss
interesting..maybe I should check mine out too..had the same issue
2011.5 mineral white e92 zcp 6mt m3
Search this Thread:
Advanced Search
