View Poll Results: Condition of rod bearings when replaced? | |||
2008-10 M3 and the rod bearings were in good shape | 14 | 20.29% | |
2011-13 M3 and the rod bearings were in good shape | 9 | 13.04% | |
2008-10 M3 and the rod bearings were in bad shape | 34 | 49.28% | |
2011-13 M3 and the rod bearings were in bad shape | 12 | 17.39% | |
Voters: 69. You may not vote on this poll |
01-05-2017, 02:56 PM | #1 |
Rep 518
POLL: Were your rod bearings in good shape when replaced?
It's claimed that only a small percentage of M3's experience accelerated rod bearing wear. In an effort to answer the question of what percentage of M3's have accelerated rod bearing wear, I've devised this simple poll: If you have had the rod bearings replace, what condition would a technician say they were in when removed?
Please include the year of your car, assessed condition, mileage, oil change habits, and approximately how many track days the engine had seen, if any. Year: 2008 Condition: Worn to the copper Miles: 123k Oil Changes: Every 10k Miles Tracked? None.
2003 M3 | SMG | KW V1 | Apex ARC-8s | 3.85 LSD | Cobra Nogaro | S2R Tuning Sunroof Delete | Billy Boat Section 3
01-05-2017, 03:39 PM | #3 |
Rep 1,678
Drives: 2011 MCB E92 M3
There is no option for mine as they were worn, but not good either.
Year: 2011 Condition: worn, but not bad. Miles: 46k Oil Changes: Every 6k Miles Tracked? None.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
01-05-2017, 04:42 PM | #4 |
Rep 118
Drives: 340i
Good idea OP, thanks for starting the poll and thread. Sub'd for results. Haven't changed my bearings yet so I cannot contribute.
now: 2017 340i M-Sport then: 2009 E92 M3 DCT |
01-05-2017, 05:19 PM | #5 |
Rep 683
My car is 2011 with 41k miles at the moment. I am probably going to do it sometime this year before Summer. I will keep this post updated with poll and picture once it is done.
01-05-2017, 06:20 PM | #6 |
Rep 4,163
Good thread!
Year: 2010 Condition: Bad. One shell was worn down to copper. The others showed wear on the first layer. Miles: 90k kms Oil Changes: Every 10k kms Tracked? Occassional |
01-06-2017, 03:39 AM | #7 |
Rep 979
MY: 2008
Condition: Worn through babbit layer on 3/4 of the bearing faces, exposed or fully worn through copper. Bad shape! Miles: ~47k Oil Changes: Every 6k, 10w 60 until bearing change, then 15w50. Tracked: Never
01-06-2017, 07:20 AM | #8 |
Rep 1,003
Drives: 2008 E90 M3 DCT Silverstone II
Year: 2008
Condition: God awful. Impending doom. Miles: Swapped at 82k (84k miles now) OCI: 7-10k mi Tracked? Not yet
Current: 08 E90 M3 DCT SSII w/ BE RB Swap, H8 Lux 180s, MS Drop-in AF, CF spoiler, CF diffuser, OEM CF leather trim, CF DCT paddles, Custom DCT flatbottom wheel, MirrorTap 9500ix, RockAuto rotors, Hawk HPS pads, AMS ECU 93 Oct Map Tune, GTS DCT update, Slambo custom undertray
01-07-2017, 11:07 AM | #9 |
Rep 255
Year: 2011
Condition: Shop said not bad for 82k miles and having supercharger on for 30k miles. Miles: 82k OCI: BMW maintenance plan 10k Tracked: never, mountain runs occasional |
01-07-2017, 11:27 AM | #10 |
Rep 2,492
Mine were acceptable
2010 E92 M3 DCT
Solo_M_Tech1687.50 |
01-07-2017, 11:40 AM | #11 |
Rep 791
Mine were junk:
http://www.m3post.com/forums/showthread.php?t=1337803 |
01-19-2017, 07:59 PM | #12 |
Rep 599
Year: 2011
Condition: Very good Miles: 52mi OCI: 6mi, with Moly Slip since 8mi (2nd owner) Tracked >40days Engine tuned, but still NA |
01-20-2017, 01:18 PM | #13 |
Rep 451
Year: 2008
Mileage: 117k Condition: worn with copper showing on several bearings OCI: 7k with Mobil 1 0w-40 Tracked once, driven hard daily
2012 E92 M3 ZCP | LeMans Blue | Bamboo Beige | 6mt | Logic7 | Extended Leather
2014 E63S AMG Wagon| Designo Diamond White| Designo Light Brown |
01-20-2017, 02:07 PM | #14 | |
Rep 1,256
It's a no brainer to use it.
01-20-2017, 06:58 PM | #15 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Hear alot of bad feedback about clogged oil filters, or it all ending up in the filter regardless. Hows it treated you
01-20-2017, 07:06 PM | #16 |
Rep 1,286
Year: 2009
Condition: Fine, would have easily gone the same mileage again. Miles: 91,000 miles Oil Changes: 7,500 miles with BMW oil until no longer available now using Liqui-Moly Tracked? Yes, at least twice per year every year |
01-20-2017, 07:12 PM | #17 |
Rep 599
I haven't had any problem with it. In fact, my mechanic said the engine was very clean. Based on condition of engine and bearings, I can't see how it has had any detrimental effects at all. I've used it in all my BMW's, and my mech swears by it.
01-20-2017, 11:53 PM | #18 |
Lord Scrip
1812
Rep 3,013
Drives: 2011 M3 Coupe
Did mine at 30,000ish and I felt the wear was a little extreme. We will see when I pull my VAC bearings at 130,000. I plan on doing them every 100,000 if my replacement bearings look as bad or worse as the originals I pulled.
01-21-2017, 10:38 AM | #19 | |
Rep 1,256
Take apart any motor which has Molyslip, and it's on every surface.
01-21-2017, 07:03 PM | #20 |
Rep 333
Where can you purchase Molyslip online if in the US? Do you just replace one quart of motor oil with it? I've been using the OEM oil and will that be fine to continue with it if using Molyslip?
11 E92 ZCP
02 Honda S2000 -741 whp 471 wtq (dynojet) @ 29.6 psi on e85; now on 34 psi, 800+ whp. |
01-21-2017, 07:14 PM | #21 |
Rep 615
Drives: E92 M3 6MT Space/Black
Molyslip's gonna be sold out now. lol
