04-02-2015, 04:52 PM | #1 |
Rep 420
Need help resetting service indicator
Can somebody please help me with instructions how to reset the service indicators on the images. The car is a E92 M3, 2008. thanks.
The best car ever: E34 M5 3.8l daytonaviolettmetallic hos Mälardalens Ventilationsceneter
04-04-2015, 07:22 AM | #7 |
Rep 420
I’ve tried the usual YouTube stuff resetting brake pad intervals, push BC button, odometer button etc. but this PITA brake pads won’t go away, when i looked at the idrive on how much mileage is left on the auto counter for the brake pad warning it’s like the pictures, just dots and no display of mileage that’s left. Already tried cutting the brake pad sensor wire and connecting them closing the circuit but no luck, do i have to code it? Any ideas?
04-04-2015, 11:13 AM | #8 |
Rep 6,722
Looks like like your pads need to be reset first. Your display shows the service interval was reset but you still have the error. You know you have two front pad sensors. Disconnect them both and then reconnect them and then reset your brakes.
04-04-2015, 04:31 PM | #10 | |
Rep 420
Found this post will try it tomorrow http://www.m3post.com/forums/showthread.php?t=840550
04-05-2015, 07:23 AM | #11 |
Rep 420
For future readers whit the same problem.
I solved it by cutting the sensor wire about 1 cm from the sensor itself and connect the two small wires under the insulation to create a closed circuit, that’s two sensors in the front and one rear, (rear right side) and then disconnected the battery for about 5 min, works fine, no more freaking brake pad warning ever. FOR PICTURES ETC SE THIS THREAD. http://www.m3post.com/forums/showthread.php?t=840550
04-05-2015, 09:00 AM | #12 |
Rep 1,711
This is what Paradocs was suggesting in his thread:
"So just cutting and splicing isn't sufficient--apparently once you cut and splice, you then have to "trick" the system into thinking that you've put in new wear sensor cables by opening the black box, unplugging the receptacle for the cable (it's the top one of the two that are in there--the other one is the cable for the wheel speed sensor) and then plugging it back in. Now the system thinks you've installed a brand new sensor cable after having put in new brake pads" You didnt have to do it? Just splice the sensor wires and disconnect the battery for 5 min? |
04-05-2015, 10:26 AM | #13 |
Rep 4,488
If you just google "Reset BMW CBS" you'll find a few videos and threads over on E90Post that explain this clearly.
As for the wear sensor, I have all three of my wear sensors just disconnected. My understanding was that as long as you disconnect them before you trip them, you don't need to worry about them anymore.
04-05-2015, 03:57 PM | #14 |
Rep 1,711
Just cut and spliced all 3 brake sensors. Disconnected battery for 30 min.
Drove the car for a while, no brake light, no problem. So, for those who want to do it, just follow these simple instructions, no need to disconnect and reconnect brake sensors. Last edited by Groundpilot; 04-05-2015 at 04:24 PM.. |
04-05-2015, 06:45 PM | #15 | |
Rep 420
04-05-2015, 06:49 PM | #16 | |
Rep 420
Sorry, se you already got it soooo nice to great rid of the warning light!!! Hade that sucker on there for almost 2 years now....
